Browse Forums Building A New House Re: Building at Northlakes Estate- Cameron park 2401Nov 26, 2015 1:18 pm We are in!! Carpet layers are up stairs doing their bit, and I'm downstairs laying the floor boards. It didn't take long before I realised I should have listened to the wife and paid someone to lay the boards lol Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building at Northlakes Estate- Cameron park 2402Nov 26, 2015 1:31 pm meminiau We are in!! Carpet layers are up stairs doing their bit, and I'm downstairs laying the floor boards. It didn't take long before I realised I should have listened to the wife and paid someone to lay the boards lol Woohoo congrats! Let's just focus on the important part of the above statement... I should have listened to the wife Re: Building at Northlakes Estate- Cameron park 2403Nov 26, 2015 1:36 pm meminiau We are in!! Carpet layers are up stairs doing their bit, and I'm downstairs laying the floor boards. It didn't take long before I realised I should have listened to the wife and paid someone to lay the boards lol Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ That floor board isn't level. How did you go with the bow in the bricks? That was your job wasn't it? Daniel Building estimator at Ford Homes Building designer after hours: Whitehaus Design & Drafting Re: Building at Northlakes Estate- Cameron park 2404Nov 26, 2015 1:40 pm Benji241 That floor board isn't level. How did you go with the bow in the bricks? That was your job wasn't it? I do have to adjust the floor unfortunately. I thought it would be level seeing that it's concrete, but no so. Apparently the steel beam isn't good enough, so they have to pull it out after Christmas. Big job, but can happen while we are in with minimum disruption. Re: Building at Northlakes Estate- Cameron park 2405Nov 26, 2015 1:43 pm meminiau Benji241 That floor board isn't level. How did you go with the bow in the bricks? That was your job wasn't it? I do have to adjust the floor unfortunately. I thought it would be level seeing that it's concrete, but no so. Apparently the steel beam isn't good enough, so they have to pull it out after Christmas. Big job, but can happen while we are in with minimum disruption. Yep. Concrete is far from perfect. Are you leveling it with ardit? The floor doesn't need to be level, just flat. You must have some big humps in the slab? Daniel Building estimator at Ford Homes Building designer after hours: Whitehaus Design & Drafting Re: Building at Northlakes Estate- Cameron park 2406Nov 26, 2015 3:53 pm The only major spot is along where the drop edge beam is. I am using stuff that I've used in the past and still had left over when I laid flooring in the home I'm in now. It is like timber, they also use it to patch up damaged timber, but also works great on concrete. Other places we had a couple bumps which disappeared once I used the masonry cutting disk on the grinder, and there were a couple places with may have originated as bubbles but when they popped they turned into small depressions. Then there is also a few scratches that occurred during the building process. I'll have it all done by tomorrow. ... hopefully! Re: Building at Northlakes Estate- Cameron park 2407Nov 26, 2015 4:15 pm meminiau The only major spot is along where the drop edge beam is. I am using stuff that I've used in the past and still had left over when I laid flooring in the home I'm in now. It is like timber, they also use it to patch up damaged timber, but also works great on concrete. Other places we had a couple bumps which disappeared once I used the masonry cutting disk on the grinder, and there were a couple places with may have originated as bubbles but when they popped they turned into small depressions. Then there is also a few scratches that occurred during the building process. I'll have it all done by tomorrow. ... hopefully! You better. All the diy husbands out there counting on you. Daniel Building estimator at Ford Homes Building designer after hours: Whitehaus Design & Drafting Re: Building at Northlakes Estate- Cameron park 2408Nov 26, 2015 4:30 pm Benji241 meminiau The only major spot is along where the drop edge beam is. I am using stuff that I've used in the past and still had left over when I laid flooring in the home I'm in now. It is like timber, they also use it to patch up damaged timber, but also works great on concrete. Other places we had a couple bumps which disappeared once I used the masonry cutting disk on the grinder, and there were a couple places with may have originated as bubbles but when they popped they turned into small depressions. Then there is also a few scratches that occurred during the building process. I'll have it all done by tomorrow. ... hopefully! You better. All the diy husbands out there counting on you. I hope not lol we could well be doomed if that's the case! Re: Building at Northlakes Estate- Cameron park 2409Nov 26, 2015 6:24 pm Any pic updates from you Benji? Re: Building at Northlakes Estate- Cameron park 2411Nov 26, 2015 6:54 pm I've ordered the pest inspection. Daniel Building estimator at Ford Homes Building designer after hours: Whitehaus Design & Drafting Re: Building at Northlakes Estate- Cameron park 2412Nov 26, 2015 6:57 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Daniel Building estimator at Ford Homes Building designer after hours: Whitehaus Design & Drafting Re: Building at Northlakes Estate- Cameron park 2413Nov 26, 2015 7:09 pm Looking great! (Apart from the dishwasher, clashes with the wood grain ?). You having waterfall ends on the island? Re: Building at Northlakes Estate- Cameron park 2414Nov 26, 2015 7:10 pm KLB Looking great! (Apart from the dishwasher, clashes with the wood grain 😜). You having waterfall ends on the island? yes to waterfalls. The back of the island is actually wrong too. It's being replaced with a lighter non wood grain panel Daniel Building estimator at Ford Homes Building designer after hours: Whitehaus Design & Drafting Re: Building at Northlakes Estate- Cameron park 2415Nov 26, 2015 7:14 pm Benji241 KLB Looking great! (Apart from the dishwasher, clashes with the wood grain 😜). You having waterfall ends on the island? yes to waterfalls. The back of the island is actually wrong too. It's being replaced with a lighter non wood grain panel Ahhhhhh ok, yeah I think that will look better, break up all the wood. Re: Building at Northlakes Estate- Cameron park 2416Nov 26, 2015 7:40 pm KLB Benji241 KLB Looking great! (Apart from the dishwasher, clashes with the wood grain 😜). You having waterfall ends on the island? yes to waterfalls. The back of the island is actually wrong too. It's being replaced with a lighter non wood grain panel Ahhhhhh ok, yeah I think that will look better, break up all the wood. That's the plan. Once the benchtop, splashback tiles and furniture go in it will break it up even further. I installed the wiring for the underfloor heating on the weekend and the waterproofing has been done. The next photos won't be until early next year now. I'll be doing the fix out over the xmas break. These are our doors though. https://www.corinthian.com.au/Products/ ... ge/Deco-7S Daniel Building estimator at Ford Homes Building designer after hours: Whitehaus Design & Drafting Re: Building at Northlakes Estate- Cameron park 2417Nov 26, 2015 7:45 pm Those doors are great, I've never seen those before. I can't even remember what doors we ended up choosing ? Re: Building at Northlakes Estate- Cameron park 2418Nov 27, 2015 5:38 pm For all those here who organized their own driveways, what payment arrangement was agreed to? A price has been agreed to and he has excavated thy general area until he hit rock, which we always knew would happen. Today he dropped some rio but that's it. Today he is asking for almost 40% of the total. Does that seem reasonable? Re: Building at Northlakes Estate- Cameron park 2419Nov 27, 2015 7:52 pm meminiau For all those here who organized their own driveways, what payment arrangement was agreed to? A price has been agreed to and he has excavated thy general area until he hit rock, which we always knew would happen. Today he dropped some rio but that's it. Today he is asking for almost 40% of the total. Does that seem reasonable? Not for digging out a little bit of rock when he already had the excavator there. The only way it would cost them a lot extra is if they went another day over time. It would have cost them an extra couple of hours at best. Machine hire is about $120 per hour. Daniel Building estimator at Ford Homes Building designer after hours: Whitehaus Design & Drafting Re: Building at Northlakes Estate- Cameron park 2420Nov 27, 2015 8:13 pm Maybe I haven't explained right. . I usually don't pay for things until I have what I'm paying for, but I do understand that with the entire cost of the job being high, that he may want some of the money up front, but I'm just not used to this sort of thing so am keen to hear about the experiences of others. All that's done so far really is to move some dirt, and he has asked me to pay $8000 now which comes of the total cost. A lot of those Covenants are put in place at the time the Developers are still involved and marketing a certain look and they get ignored or expire after a time. If the… 1 3333 Elvis has left the building... The site supervisor quit after 2 month on the project. I guess he was just instructed to bark at people, but didn't like when he was… 26 22262 |
