Good luck with the DRP.
Post up some plans, I'm keen to see what you have gone with!
Browse Forums Building A New House Re: Building Washington 29 from Wisdom Home 21Jun 20, 2013 1:53 pm Transformation Finally I received my draft plan which is now sent to DRP. It was really exciting as Wisdom did a great job. Washington 29 looks nice with Avanti facade. Good luck with the DRP. Post up some plans, I'm keen to see what you have gone with! Re: Building Washington 29 from Wisdom Home 22Jun 20, 2013 3:13 pm htaco Transformation Finally I received my draft plan which is now sent to DRP. It was really exciting as Wisdom did a great job. Washington 29 looks nice with Avanti facade. Good luck with the DRP. Post up some plans, I'm keen to see what you have gone with! DRP came back with numbers of requirements. The following comments are made: 1. The guidelines require changes of materials / colours to all four elevations. The proposed dwelling provides minimal render and cladding to the front facade and no change in material on the western side elevation as required. Please provide additional change of materials / colours to the front elevation and western side elevation. As a minimum the total recessed area provided in the centre of the western facade would need to be provided with a change in material / colour. – I will provide moroak on garage, use light matrials on the side. 2. The front facade provides a large balcony within the front articulation zone, which provides a variation to the maximum width requirement. The balcony is 46.2% of the building width and exceeds the requirement maximum of 45%. The DRP will accept this minor variation subject to all other issues being addressed satisfactorily. Please note that Council may still raise an issue. 3. The materials on the front northern facade must return along the sides a minimum distance of 2m. The front face brick does not return a minimum distance of 2m along the eastern side of bed 1. The DRP suggest that the design provides additional light weight material on the front facade to address this issue and issue 1 above. Please amend. 4. The garage parapet is to return a minimum distance of 350mm and is to be dimensioned. It is 350, Wisdom will dimension it accordingly. 5. The rear FC sheeting is to be provided with concealed or flush joints. Wisdom will provide pricing for this and add it to tender accordingly. 6. The eastern wall of the leisure is to be provided with a slim line vertical / horizontal open-able (or small open-able) window to maximise cross flow ventilation. This is where my tank is located. I need to push it further. 7. The eastern wall of the bed 3 is to be provided with a slim line vertical / horizontal open-able (or small open-able) window to maximise cross flow ventilation. Provide AS0618 to Bed 3. 8. The western wall of the bed 1 is to be provided with a slim line vertical / horizontal open-able (or small open-able) window to maximise cross flow ventilation. As above to Master Suite. 9. The western wall of the bed 2 is to be provided with a slim line vertical / horizontal open-able (or small open-able) window to maximise cross flow ventilation. As above to Bed 2. 10. The guidelines require wall lengths greater than 14m to be provided with a break / step with a minimum depth of 600mm and min. 1.8m wide and the roof line and eaves are to follow the line of the step. The western first floor facade is greater than 14m in length and does not provide a 600mm recessed area and the roof line does not follow the step. Please amend. The recess alcove needs to be 600mm. Increase the depth by 120mm and amend roofline to follow. Wisdom will push the stairs out 120mm to suit this, thereby taking a small amount from the Powder Room Vanity and keeping the hallway the same width, and pushing the stairs into the upper hall a small amount as it is wide enough to take space from. 11. The driveway area (width) within the site is large and will dominate the front setback area. Please reduce the width of the driveway and concrete area to increase landscaped area. Wisdom will revise the plan. 12. The driveway is to be a max. width of 4m at the property boundary and min. 1m from the side boundary. The front path is to have a maximum width of 900mm. As above. 13. It is recommended that the western lounge, dining and bed 1 and 2 windows are provided with performance glazing. This is not compulsory, only recommended, so I don’t need to worry about this. All these requirements are costing me $3700. Find Out About Bungarribee Community At http://bungarribee.com Building Washington 29 from Wisdom Homes - viewtopic.php?f=31&t=63920&p=1011725#p1011725 Re: Building Washington 29 from Wisdom Home 23Jun 20, 2013 3:24 pm Wisdom required 8 days to revise the plan. This means DRP need to review the revised plan and if all well pre-approve it. My settlement date was on 18th of June so this means I need to pay interest for everyday i am delaying the settlement. To my knowledge it will be atleast 10 days if Wisdom revise the plan within 8 days. Not happy Find Out About Bungarribee Community At http://bungarribee.com Building Washington 29 from Wisdom Homes - viewtopic.php?f=31&t=63920&p=1011725#p1011725 Re: Building Washington 29 from Wisdom Home 24Jun 20, 2013 3:30 pm Fingers crossed that is all for the DRP. I've seen the DRP pick on a lot of rooms for "cross ventilation". What exactly do they mean? is this an extra window on a wall that didn't have one so there is air flow? Re: Building Washington 29 from Wisdom Home 25Jun 20, 2013 3:33 pm htaco Fingers crossed that is all for the DRP. I've seen the DRP pick on a lot of rooms for "cross ventilation". What exactly do they mean? is this an extra window on a wall that didn't have one so there is air flow? That's correct. Wisdom charge $370 to $500 per window depending on the size. I needed to include 4 extra windows 3 on bedrooms and one on leisure. Find Out About Bungarribee Community At http://bungarribee.com Building Washington 29 from Wisdom Homes - viewtopic.php?f=31&t=63920&p=1011725#p1011725 Re: Building Washington 29 from Wisdom Home 26Jun 20, 2013 3:52 pm If it was my case, I would not be happy at all !! I am pretty sure it is not the first time for Wisdom to build in your area, so they should pretty much be aware of all the requirements of developer/ council in your area. Re: Building Washington 29 from Wisdom Home 27Jun 20, 2013 3:57 pm avalanche If it was my case, I would not be happy at all !! I am pretty sure it is not the first time for Wisdom to build in your area, so they should pretty much be aware of all the requirements of developer/ council in your area. Can't agree more. I have also gave them enough heads up about DRP requirements and timing. But they chose to ignore it and guess what I will be paying over $1000 interest because of that. Find Out About Bungarribee Community At http://bungarribee.com Building Washington 29 from Wisdom Homes - viewtopic.php?f=31&t=63920&p=1011725#p1011725 Re: Building Washington 29 from Wisdom Home 28Jun 20, 2013 4:04 pm Have you tried talking to your CSO about it? that you should not be penalized due to their mistakes Re: Building Washington 29 from Wisdom Home 29Jun 20, 2013 4:08 pm Yes but i was told that's their process. Find Out About Bungarribee Community At http://bungarribee.com Building Washington 29 from Wisdom Homes - viewtopic.php?f=31&t=63920&p=1011725#p1011725 Re: Building Washington 29 from Wisdom Home 30Jun 22, 2013 6:40 pm Transformation Quote: Can't agree more. I have also gave them enough heads up about DRP requirements and timing. But they chose to ignore it and guess what I will be paying over $1000 interest because of that. Sorry to hear that, it must be extremely frustrating that your advice to W was not listened to. Hope they get it right and approval won't be too far away. We built the Wisdom Majestic 40 - moved in! Our blog - http://ourwisdommajestic40.blogspot.com.au/ Our H1 thread - viewtopic.php?t=54156 Re: Building Washington 29 from Wisdom Home 31Jun 24, 2013 9:33 pm DRP pre-approval received. The DRP director went above and beyond to pre-approve my plan with subject to the following being detailed on the full DRP application: 1. The front elevation is considered satisfactory subject to the render extending to the front door wall. 2. The northern window treatment is considered satisfactory. 3. The garage parapet is to return a minimum distance of 350mm and is to be dimensioned. This has not been done and needs to be provided with the full application. 4. The guidelines require wall lengths greater than 14m to be provided with a break / step with a minimum depth of 600mm and min. 1.8m wide and the roof line and eaves are to follow the line of the step. The western first floor facade is greater than 14m in length and now provides a 600mm recessed area but the roof line does not follow the step. Please amend the roofline so it steps in with the recessed area. 5. The driveway area (width) within the site is large and will dominate the front setback area. Please reduce the width of the driveway and concrete area to increase landscaped area. 6. The site coverage is complying, but please ensure the landscaped area is compliant with the full DRP application, which excludes the paved areas and water tank and must have a minimum dimensions of 2.5m each way. Please also detail front and rear landscaped area compliance. 7. The driveway is to be a max. width of 4m at the property boundary and min. 1m from the side boundary. The front path is to have a maximum width of 900mm. 8. It is recommended that the western lounge, dining and bed 1 and 2 windows are provided with performance glazing. Next step is to sign contract and request date for settlement. At the moment looking at 27th of June for settlement subject to Landcom and my conveyancer. Total interest is payable for 9 days. Find Out About Bungarribee Community At http://bungarribee.com Building Washington 29 from Wisdom Homes - viewtopic.php?f=31&t=63920&p=1011725#p1011725 Re: Building Washington 29 from Wisdom Home 32Jun 24, 2013 10:45 pm Congrats on the preapproval, great they got it done for you. A small step closer to starting your build We built the Wisdom Majestic 40 - moved in! Our blog - http://ourwisdommajestic40.blogspot.com.au/ Our H1 thread - viewtopic.php?t=54156 Re: Building Washington 29 from Wisdom Home 33Jun 25, 2013 8:55 am Thanks Onewheel. This week gonna be hectic for me.... Find Out About Bungarribee Community At http://bungarribee.com Building Washington 29 from Wisdom Homes - viewtopic.php?f=31&t=63920&p=1011725#p1011725 Re: Building Washington 29 from Wisdom Home 34Jun 28, 2013 11:50 am Building contract is signed and settled on land. Paid $820 interest for delayed settlement. Find Out About Bungarribee Community At http://bungarribee.com Building Washington 29 from Wisdom Homes - viewtopic.php?f=31&t=63920&p=1011725#p1011725 Re: Building Washington 29 from Wisdom Home 36Jun 28, 2013 12:59 pm Transformation Building contract is signed and settled on land. Paid $820 interest for delayed settlement. Ouch!!! At least you have settled now We built the Wisdom Majestic 40 - moved in! Our blog - http://ourwisdommajestic40.blogspot.com.au/ Our H1 thread - viewtopic.php?t=54156 Re: Building Washington 29 from Wisdom Home 37Jun 28, 2013 1:58 pm Congrats Transformation! So whats the process from here? Is it council DA approval or do you need to still finalise with the developer first?..Sorry I am not sure how it works with new estates.. Re: Building Washington 29 from Wisdom Home 38Jun 28, 2013 2:13 pm Thanks everyone! I wish I could use the $820 on electrical. I guess that's the fun of building a house. You will always have suprise cost. @Aheron, next step is colour appoinment, landscaping appointment and brick selectection. Once done the final plan will go to DRP for final approval. Once DRP approve it will then go to DA approval. Still long way to go Find Out About Bungarribee Community At http://bungarribee.com Building Washington 29 from Wisdom Homes - viewtopic.php?f=31&t=63920&p=1011725#p1011725 Re: Building Washington 29 from Wisdom Home 39Jun 28, 2013 2:39 pm Is Wisdom as slow between contract signed and construction start? I found them quite slow from tender acceptence till contract signed. Is it going to be the same/worst/better? Find Out About Bungarribee Community At http://bungarribee.com Building Washington 29 from Wisdom Homes - viewtopic.php?f=31&t=63920&p=1011725#p1011725 Re: Building Washington 29 from Wisdom Home 40Jun 28, 2013 3:10 pm I am sure it changes from job to job, but for us they took 3 months from tender acceptance to contract signing, then another 7 months to actually start on site...of the 7 months prob 2-3 weeks was lost due to the xmas period...from my experience and reading others, the most frustrating part is after council approval where they take 2-3 months to start in comparison to others who are on site witin 4 weeks enjoy the next part as selecting colours etc is the most exciting part of the admin process! Hi, guys! If you've built with Wisdom Homes, would you mind sharing images of your front facades once they're all rendered? I'm considering signing up with them for a wide… 0 15348 Can someone please offer some advice? Im DESPERATE. Because I'm completely and utterly exhausted. How long are variations taking with other companies at the moment? We… 0 19721 In fairness nobody gave a crap about the ACCC and the gag clauses continued in the pro forma templates of a few other builders after the ACCC took on Wisdom, and more… 19 75488 |
