Browse Forums Building A New House Re: NEED URGENT HELP re. Overhang 21Jan 05, 2010 9:22 pm Yes, there is a bit of overhang, which means that there is still quite some slab under the frame. So, they would dynabolt the frame to the slab, ovbiously from the side of the frame which is opposite to the overhang. The frame is 9cm, the overhang is about 1.5cm ... Anyway, I'm wondering if one fixing option is better than the other (ie. grout vs. dynabolt) and what are the governing factors in choosing one over another ... My signature is distracting people from my wise posts ... Re: NEED URGENT HELP re. Overhang 22Jan 07, 2010 6:35 am We had a similar issue. They applied non-shrink grout (Barrafill) in a fairly amateur way, so we asked for the engineering documents and certification. They provided the docs, which showed that much more fixing is required... they need to graft, with dowels (400mm every 200mm) and y bars. I'd ask too see documentation... Re: NEED URGENT HELP re. Overhang 23Jan 07, 2010 8:49 am JuniorMin We had a similar issue. They applied non-shrink grout (Barrafill) in a fairly amateur way, so we asked for the engineering documents and certification. They provided the docs, which showed that much more fixing is required... they need to graft, with dowels (400mm every 200mm) and y bars. I'd ask too see documentation... OMG ... How much overhang did you have??? Ours is only 1.5cm (1cm max allowed according to the current standards). When you say they gave you the docs, did they indeed consult the engineer to design the rectification (on drawings)??? And then forwarded you the drawings? We keep asking for engineer involvement, they keep saying it's not needed. BTW, cant find what Y bars are .. My signature is distracting people from my wise posts ... Re: NEED URGENT HELP re. Overhang 24Jan 07, 2010 8:56 am Lex BTW, cant find what Y bars are .. Y-bars are reinforcement bars The Y is an old (2 year approx) designation, it's now L and N which refers to the ductility of the bar. Drawings should show bars as N and then a diameter...e.g. N12 mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Re: NEED URGENT HELP re. Overhang 25Jan 07, 2010 9:24 am Aha, thanks tdl! I'm (very ) familiar with N bars, especially N12 ... I think there are also Z bars, I think they are a good design practice as they seem to be the "linking" type of reo between different heights of the slab (of course, we don't have them) ... not sure, just my amateurism talking ... My signature is distracting people from my wise posts ... Re: NEED URGENT HELP re. Overhang 26Jan 07, 2010 9:39 am Enough ginning around Lex... Time to get an indepedant engineer involved... A proper one! Electrical Engineer... Don't hold that against me... And keen owner builder... Mainly the building part!! Re: NEED URGENT HELP re. Overhang 27Jan 07, 2010 10:39 am Lex Aha, thanks tdl! I'm (very ) familiar with N bars, especially N12 ... I think there are also Z bars, I think they are a good design practice as they seem to be the "linking" type of reo between different heights of the slab (of course, we don't have them) ... not sure, just my amateurism talking ... I think we are at cross-purposes...N and L are ductility classifications (Normal and Low)...Z bars and other designate a shape and there are a gazillion shapes which vary depending on requirement. http://www.mainroads.qld.gov.au/~/media ... 1043-1.pdf Depends a bit on the scheduler and engineering drawings (although it is relatively standard) something like 16-L16N @ 200 means 16 No. L-shape 16 dia N grade bars @ 200 centres... mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Re: NEED URGENT HELP re. Overhang 28Jan 07, 2010 10:55 am Thanks, tdl, great info here! BTW, I mentioned the Z ones specifically because I think they can be useful for house (foundations) construction just because they seem to be able to provide that continuous vertical-horizontal reinforcement in an unbroken line. Whether they are needed in each specific case of course needs to be judged by a pro ... but, not really useful of me rambling about things I am not educated in anyway ... My signature is distracting people from my wise posts ... Thank you @. Tried to play with the facade models but the exact colour is not matching up. 2 3655 In the end, two pieces of treated timber (20mm thick) were bolted onto the joists and planed when there was too much sticking out. Passed inspection. 13 8048 Thanks Ardo, they are sort of semi concealed. I think it is only a few millimetres. I see if they can adjust the hinges. 4 4082 |
