Browse Forums Building A New House Re: 22Feb 16, 2010 4:35 pm mattwalker claego! FRAME STAGE IS THE MOST IMPORTANT INSPECTION! The plumbing, electrical, wall placement, framing, trusses can all be inspected! This is where the builder gets to hide ALL the ******* stuff. Thinkgs like copper touching metal (Very bad!!) rips in sisal, bad plumbing and electrical, walls out of square and not in the right spots, lack of corner blocks in framing .... etc etc... All of this is covered! OK, so some of the biggies at this stage are (apart from the obvious things which should be taken care of by the PCA - such as compliance with the Plans, council, Basix, etc.):
Can anyone add to this? Also, can anyone add some of their problems and how were they fixed? My signature is distracting people from my wise posts ... Re: Pre-plaster inspection - important or not? 23Mar 19, 2010 8:31 pm Hi all Yes, the frame is importaint and so is the rest to the house. As to DIY inspection on a basic B.V. single story home I say why not do it your self. The frame must be streight and on the lines marked out. Bottom plate attached to slab as per code & tolerances guild. Must be solid, solid, solid, no movement in the walls. Smash more nails in if you think it needs it. Add a noggen here & there and your away. Of course you need to have seen a few good frames before and a basic knowledge, but not a degree in construction. I would like to know of what people have found on their frame inspection that was not up to standard. Thanks Kindly KW.................... “It's just as unpleasant to get more than you bargain for as to get less” George Bernard Shaw. Re: Pre-plaster inspection - important or not? 24Mar 19, 2010 9:59 pm KW... Good luck with the DIY! Please whilst you are at it...explain to me what a corner block is? Or perhaps a wall plate! Re: Pre-plaster inspection - important or not? 25Mar 22, 2010 3:04 pm Matt Its the block at the end of your street. Regards KW............................ “It's just as unpleasant to get more than you bargain for as to get less” George Bernard Shaw. Re: Pre-plaster inspection - important or not? 26Mar 22, 2010 3:14 pm Excellent...best of luck with that DIY inspection The worst thing you can do is sign a building contract without a pre contract review. Over the years many people have come to me with disputes where they just signed… 0 8806 There are a lot of private inspectors should have stayed working as tradies!! Firstly, you paid for a professional opinion of the works, if he has picked up on an item he… 1 2523 Hi, Have used the Dulux 1 step, oil base on my walls(white set), out of can it’s already a more thinner product than a final coat paint Also in water base Water or… 3 5335 |
