Browse Forums Building A New House Re: Masterton Homes - The next thread 4.0 14581Dec 30, 2022 10:06 am [quote="Fisher75"]Hi Everyone, Just wanted your opinion on the situation. I've built with Masterton, recently I had a flood downstairs, because the shower drain got a bit clogged and the water filled up about 15mm. It did not go outside of shower cabin. As the water was going through the drain some of it went under the tiles travelled to the bathtub drain area and went downstairs. Apparently there is a gap between the shower drain pipe and the drain hole, which is according to Masterton "by design", and this allows the water to travel between the floor tiles and the waterproofing. There supposed to be a little barrier around the hole in the floor where the bathtub drain pipe goes through. Apparently it is either not sealed or the water goes above it. Masterton called a waterproofer, who inspected the bathroom and said he will tell Masterton how to fix it. Masterton came back to me later saying this is not their problem, as "the water filled above the angle which allows the water to go where ever. There is not water proofing problem. Need to keep floor waste free of body hair". I asked for a copy water proofer's report, so I have something in writing. Never got it. I refuse to believe that hair in the drain should be causing floods downstairs as long as the water does not leave the tiled floor of the bathroom. What do you think? I would write to product review, I find companies action complaints on there as it's bad for there reputation Good Luck with it all KDR. Overture Premier 09/14 $3900 10/14 Plans 11/14 Contracts 03/15 Demo 04/15 Validation 05/15 Slab 06/15 Frame 06/15 Bricks 09/15 lock up 16/12/15 Keys Re: Masterton Homes - The next thread 4.0 14582Dec 30, 2022 10:10 am Fisher75 Have you tried writing on Product Review this usually gets companies actioning complaints quicker as it's bad for there reputation . KDR. Overture Premier 09/14 $3900 10/14 Plans 11/14 Contracts 03/15 Demo 04/15 Validation 05/15 Slab 06/15 Frame 06/15 Bricks 09/15 lock up 16/12/15 Keys Re: Masterton Homes - The next thread 4.0 14583Dec 30, 2022 12:41 pm Good waterproofers do the whole area of the bathroom up to 150mm above the raw floor height. Masterton and many project home builders do the bare minimum and only cover the puddle flange and corners. I don’t know how you have a shower and not realise that it is pooling but even if it does pool a shower should cope with water retention rather than spilling under the tiles. This is almost the building standards fault rather than the actually water proofing as the standard allows them to only partially seal a bathroom. I’ve seen our water proofing in the project home vs a timer who redid an ensuite for us. I know which one won’t leak ever. Good luck with you fight but persist. marina12 Fisher75 Hi Everyone, Just wanted your opinion on the situation. I've built with Masterton, recently I had a flood downstairs, because the shower drain got a bit clogged and the water filled up about 15mm. It did not go outside of shower cabin. As the water was going through the drain some of it went under the tiles travelled to the bathtub drain area and went downstairs. Apparently there is a gap between the shower drain pipe and the drain hole, which is according to Masterton "by design", and this allows the water to travel between the floor tiles and the waterproofing. There supposed to be a little barrier around the hole in the floor where the bathtub drain pipe goes through. Apparently it is either not sealed or the water goes above it. Masterton called a waterproofer, who inspected the bathroom and said he will tell Masterton how to fix it. Masterton came back to me later saying this is not their problem, as "the water filled above the angle which allows the water to go where ever. There is not water proofing problem. Need to keep floor waste free of body hair". I asked for a copy water proofer's report, so I have something in writing. Never got it. I refuse to believe that hair in the drain should be causing floods downstairs as long as the water does not leave the tiled floor of the bathroom. What do you think? I would write to product review, I find companies action complaints on there as it's bad for there reputation Good Luck with it all Building Symphony Grande Custom Masterton House and Land 12/6/14 Paid $3500 20/11/14 contracts signed deposit paid Re: Masterton Homes - The next thread 4.0 14584Jan 01, 2023 5:48 pm marina12 Fisher75 Have you tried writing on Product Review this usually gets companies actioning complaints quicker as it's bad for there reputation . I will, and also will engage the Office of Fair Trading and their insurance. But before that I want to understand if this is a defect and their fault. This is my main question. I am attaching the diagram on how I think the leak happens to better explain the problem. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 2014 30/05 $3900 25/08 Contracts 02/10 DA submitted 2015 17/02 DA approved 02/04 Colors 10/04 Demo 09/07 Construction start 27/07 Fill 15/08 Slab 21/09 Frame 2016 08/01 Bricks Re: Masterton Homes - The next thread 4.0 14585Jan 01, 2023 5:51 pm brettbert Good waterproofers do the whole area of the bathroom up to 150mm above the raw floor height. Masterton and many project home builders do the bare minimum and only cover the puddle flange and corners. I don’t know how you have a shower and not realise that it is pooling but even if it does pool a shower should cope with water retention rather than spilling under the tiles. This is almost the building standards fault rather than the actually water proofing as the standard allows them to only partially seal a bathroom. I’ve seen our water proofing in the project home vs a timer who redid an ensuite for us. I know which one won’t leak ever. Good luck with you fight but persist. marina12 Fisher75 Hi Everyone, Just wanted your opinion on the situation. I've built with Masterton, recently I had a flood downstairs, because the shower drain got a bit clogged and the water filled up about 15mm. It did not go outside of shower cabin. As the water was going through the drain some of it went under the tiles travelled to the bathtub drain area and went downstairs. Apparently there is a gap between the shower drain pipe and the drain hole, which is according to Masterton "by design", and this allows the water to travel between the floor tiles and the waterproofing. There supposed to be a little barrier around the hole in the floor where the bathtub drain pipe goes through. Apparently it is either not sealed or the water goes above it. Masterton called a waterproofer, who inspected the bathroom and said he will tell Masterton how to fix it. Masterton came back to me later saying this is not their problem, as "the water filled above the angle which allows the water to go where ever. There is not water proofing problem. Need to keep floor waste free of body hair". I asked for a copy water proofer's report, so I have something in writing. Never got it. I refuse to believe that hair in the drain should be causing floods downstairs as long as the water does not leave the tiled floor of the bathroom. What do you think? I would write to product review, I find companies action complaints on there as it's bad for there reputation Good Luck with it all This is the bathroom kids use, so when they were younger they used the bath tab and the shower was used not frequently. So it never got clogged and never puddled before. Now the kids started using the shower more and once it clogged I got flooding downstairs. I am trying to check it on regular basis, but would prefer a shower that copes with a bit of a puddling. 2014 30/05 $3900 25/08 Contracts 02/10 DA submitted 2015 17/02 DA approved 02/04 Colors 10/04 Demo 09/07 Construction start 27/07 Fill 15/08 Slab 21/09 Frame 2016 08/01 Bricks 4 17121 i imagine you also have another contract with an architect? and yeah, whatever other's said about special conditions and appendices 16 16479 Hi all I am looking to run a water line under my concrete footpath which is directly next to my home, was seeing if this is possible without cutting the entire section… 0 20635 |
