Browse Forums Building A New House Re: Who else is building with Eden Brae? 13501Apr 01, 2016 1:11 am Hi guys, I am having the same issue with steve_la, land has just settled at Edmondson park and ebh said has lodged our DA application 2 weeks ago to Liverpool council, however our da application is nowhere to be found! I checked council da eportal online and also I called up council but the officer said they cant find any da application for my lot. ebh cso adamant n said they have sent it and takes awhile for council to load, hope they don't just bull. Anyone can share some experience? I don't want to sound demanding / pushy to the cso but I also need at least try to speed things up. Been paying 7m penalty 1k a month since our land rego been delayed for that long Who else is building with Eden Brae? 13502Apr 01, 2016 6:45 am It took nearly 3 months before my council even knew the paperwork was with them lol! Then they didn't know how to process it because it was at the time that there was a code change...my cso then went to private certifier, which was done in approx 2 weeks. All the best with it Sent using Tapatalk Re: Who else is building with Eden Brae? 13503Apr 01, 2016 9:51 am well, building is a big headache with me atm , I am building a single storey and had paid 4 months late fee , they gave me a discount but its still a lot of money to me and to everyone who has the same problem. I dont know if they are going to give me discount again or not . Thanks PixiGT anyways Re: Who else is building with Eden Brae? 13504Apr 01, 2016 5:24 pm Hi Guys Getting in trouble with my landscape plan again. I didnt do it through EBH because they charge me $800 or so for that . Tried to draw it myself using Photoshop, but I don't think it is going to be approved by Fairfield Council, because it is too simple . I have upload it on here so, hope some one could help me a bit by giving me advice or if possible It would be appreciate if anyone could upload their landscape plan . Thank you so much guys Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Who else is building with Eden Brae? 13505Apr 02, 2016 5:55 pm Hi you need to look at the developer requirements and then follow them with design. You don't need to concentrate on rear of the home to much. I suggest to put less trees/plants at rear because in the future you have option to add more. Usually you put one tree at the back and same shrubs at the front with flexibility to add if you wish. Design is for DA approval only you don't have to do exactly same design later, however the amount of grass and plants etc can't be less then in proposal. Hope that help. Re: Who else is building with Eden Brae? 13506Apr 04, 2016 7:34 pm Question re chipped bricks. If the bricks are painted (we have Chocolatta) and they are chipped, does EBH replace each chipped one? Re: Who else is building with Eden Brae? 13507Apr 04, 2016 8:12 pm Lincoln35_mckinley Question re chipped bricks. If the bricks are painted (we have Chocolatta) and they are chipped, does EBH replace each chipped one? I'll like to know this also. I believe they fill in the chip and paint over it. Re: Who else is building with Eden Brae? 13508Apr 04, 2016 8:15 pm swiftsport Lincoln35_mckinley Question re chipped bricks. If the bricks are painted (we have Chocolatta) and they are chipped, does EBH replace each chipped one? I'll like to know this also. I believe they fill in the chip and paint over it. That's what hubby thought too! I just couldn't see them removing each offending brick and replacing them. Surely that's a big job. And the brick work gets very messy so it's very likely that they'll get chipped during the process and cleaning too. Re: Who else is building with Eden Brae? 13509Apr 04, 2016 8:19 pm We drive around looking at builds and saw a garage section with almost a quarter chipped away wife asked how they going to explain to the owners, then week after drove past again and it was fixed. I believe they fill it in no way they can remove brick and replace it. Re: Who else is building with Eden Brae? 13510Apr 04, 2016 8:22 pm swiftsport We drive around looking at builds and saw a garage section with almost a quarter chipped away wife asked how they going to explain to the owners, then week after drove past again and it was fixed. I believe they fill it in no way they can remove brick and replace it. Makes sense. I was able to find this on an older post too: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Who else is building with Eden Brae? 13511Apr 05, 2016 6:36 am swiftsport We drive around looking at builds and saw a garage section with almost a quarter chipped away wife asked how they going to explain to the owners, then week after drove past again and it was fixed. I believe they fill it in no way they can remove brick and replace it. Hi guys, I'm a little rusty on what would be deemed bad enough to remove/replace in terms of your bricks (independent inspector could fill you in if you have one to call), however just wanted to let you know that bricks can be removed & replaced as needed, when done carefully; I had some bricks removed around the bbq gas bayonet on the side alfresco wall, & they were removed/replaced without issue (job was done due to a gas leak in the wall cavity at that location when the gas was turned on, giving my house a slight ka-boom risk lol). Good luck with it Re: Who else is building with Eden Brae? 13512Apr 05, 2016 3:22 pm Steven_La Hi Guys Getting in trouble with my landscape plan again. I didnt do it through EBH because they charge me $800 or so for that . Tried to draw it myself using Photoshop, but I don't think it is going to be approved by Fairfield Council, because it is too simple . I have upload it on here so, hope some one could help me a bit by giving me advice or if possible It would be appreciate if anyone could upload their landscape plan . Thank you so much guys Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ i was like you, then I decided I couldn't be bothered doing it myself! if you need a professional landscape plan, go try Bluegum Design http://bluegumdesign.com.au they did mine for $395 and it was great. Certainly cheaper than the ridiculous $800 eden brae tried charging me too. Re: Who else is building with Eden Brae? 13513Apr 06, 2016 10:11 am JP19833 Steven_La Hi Guys Getting in trouble with my landscape plan again. I didnt do it through EBH because they charge me $800 or so for that . Tried to draw it myself using Photoshop, but I don't think it is going to be approved by Fairfield Council, because it is too simple . I have upload it on here so, hope some one could help me a bit by giving me advice or if possible It would be appreciate if anyone could upload their landscape plan . Thank you so much guys i was like you, then I decided I couldn't be bothered doing it myself! if you need a professional landscape plan, go try Bluegum Design http://bluegumdesign.com.au they did mine for $395 and it was great. Certainly cheaper than the ridiculous $800 eden brae tried charging me too. Thanks for that, but I have done my one with Nadeen helps, I took me a whole day lol . When I finished my one, I emailed council and they said its acceptable , so saving me a few hundred bucks. Re: Who else is building with Eden Brae? 13516Apr 07, 2016 3:47 pm kbhouse Hi, I'm very new to the forum (joined just now!). May I ask...how much is Eden Brae charging for the render finish (part of the house) on your houses? Hi Kbhouse I would suggest do the render after handover. As EBH will charge you double the price. We been quoted for render $7000 by EBH. This sounds expensive to me so I didn’t accept that quote. We had someone from outside and he did the same render for only $3000. So we saved $4000 which I can use for something else. All the best.. Tender signed 14/04/2015 Contract signed 28/04/2015 Council Approval 23/06/2015 http://lincoln30mkii.blogspot.com.au/ Re: Who else is building with Eden Brae? 13517Apr 07, 2016 4:08 pm Thanks so much for your replies! That's our situation too. EBH is charging over $6000 for 1/3 of the house which I think is way over the top. The thing is we're far down the track in the admin process. We already have the developer and council approvals and are about to sign off on the final documents. Is it possible at this point to take it off (ie just a matter of raising a PCV to delete the render), or is it much more complicated than that? Re: Who else is building with Eden Brae? 13519Apr 07, 2016 5:41 pm kbhouse Thanks so much for your replies! That's our situation too. EBH is charging over $6000 for 1/3 of the house which I think is way over the top. The thing is we're far down the track in the admin process. We already have the developer and council approvals and are about to sign off on the final documents. Is it possible at this point to take it off (ie just a matter of raising a PCV to delete the render), or is it much more complicated than that? Don't forget that if the rendering is part of your DA and developer approval, you will probably not be able to get an occupancy certificate until it is done and certified. Deposit paid 3/9/14. Tender signed 3/10/14. Contract signed 22/10/14 Construction commenced September 2015 PCI 7/3/16 Re: Who else is building with Eden Brae? 13520Apr 07, 2016 7:03 pm Marko56 kbhouse Thanks so much for your replies! That's our situation too. EBH is charging over $6000 for 1/3 of the house which I think is way over the top. The thing is we're far down the track in the admin process. We already have the developer and council approvals and are about to sign off on the final documents. Is it possible at this point to take it off (ie just a matter of raising a PCV to delete the render), or is it much more complicated than that? Don't forget that if the rendering is part of your DA and developer approval, you will probably not be able to get an occupancy certificate until it is done and certified. Agreed: the final OC won't be issued till its done if required for DA, but an interim OC would be granted (lasting 3 months)...just have a chat to EBH & they will fill you in when you remove the render I built with EB back on 2009. Check out this thread on this forum. viewtopic.php?f=31&t=12911&p=154061#p154061 I can't speak for recent expericience however, we had no… 1 23927 A survey must’ve completed by a certified surveyor. This form part of every DA requirement 3 225938 |
