Browse Forums Building A New House Re: Building with Wisdom Homes 12681Sep 26, 2018 2:55 pm Haha Jenifermarie at least you weren’t rushed All our tapware is from RogerSellers so Reece just purchased off them https://www.rogerseller.com.au/pinch-pr ... let-chrome Re: Building with Wisdom Homes 12683Sep 26, 2018 4:08 pm champs2018 - It does not require extra plumbing but it is a plumber's job though. You may be charged $80 by a decent plumber. We have done it in one of our renovations. We will be changing it post handover but not very immediate. If you think you are going to immediately change post handover then get W arrange your desired ones as suggested as otherwise it will be a waste. We did not change any of the bath fittings however we changed kitchen tabs n sinks and it was quite easy with W and as far as I rem no extra charge apart from variation. Re: Building with Wisdom Homes 12684Sep 26, 2018 5:19 pm ASJ1981 kingofnowhere Any one know the brand of windows wisdom use, trying to increase a window size and would like to know the options available. Trend Windows and Doors Product Review is your friend and a visit is now recommended. Re: Building with Wisdom Homes 12685Sep 26, 2018 6:20 pm aaron2008 @champs2018 - It does not require extra plumbing but it is a plumber's job though. You may be charged $80 by a decent plumber. We have done it in one of our renovations. We will be changing it post handover but not very immediate. If you think you are going to immediately change post handover then get W arrange your desired ones as suggested as otherwise it will be a waste. We did not change any of the bath fittings however we changed kitchen tabs n sinks and it was quite easy with W and as far as I rem no extra charge apart from variation. Thanks everyone.. yes we didnt like anything from the website..maybe a visit to Reece is worthwhile then. Shall look into it then Re: Building with Wisdom Homes 12686Sep 26, 2018 6:26 pm champs2018 aaron2008 @champs2018 - It does not require extra plumbing but it is a plumber's job though. You may be charged $80 by a decent plumber. We have done it in one of our renovations. We will be changing it post handover but not very immediate. If you think you are going to immediately change post handover then get W arrange your desired ones as suggested as otherwise it will be a waste. We did not change any of the bath fittings however we changed kitchen tabs n sinks and it was quite easy with W and as far as I rem no extra charge apart from variation. Thanks everyone.. yes we didnt like anything from the website..maybe a visit to Reece is worthwhile then. Shall look into it then You will find the exact same stuff at the Reece store as on the website. You need to look at other bathroom retailers and get the product codes. You can give these to your colours person for quotes. Domayne Alexandria have a fairly big range and Cass brothers is also a good one. Re: Building with Wisdom Homes 12687Sep 26, 2018 6:34 pm Manhattan52 champs2018 aaron2008 @champs2018 - It does not require extra plumbing but it is a plumber's job though. You may be charged $80 by a decent plumber. We have done it in one of our renovations. We will be changing it post handover but not very immediate. If you think you are going to immediately change post handover then get W arrange your desired ones as suggested as otherwise it will be a waste. We did not change any of the bath fittings however we changed kitchen tabs n sinks and it was quite easy with W and as far as I rem no extra charge apart from variation. Thanks everyone.. yes we didnt like anything from the website..maybe a visit to Reece is worthwhile then. Shall look into it then You will find the exact same stuff at the Reece store as on the website. You need to look at other bathroom retailers and get the product codes. You can give these to your colours person for quotes. Domayne Alexandria have a fairly big range and Cass brothers is also a good one. Oh ok..we have a grohe handrail at our current house and we liked it better than wisdoms standard handrail and reece did not have this. Will visit them and show if they can source it for us. Re: Building with Wisdom Homes 12688Sep 26, 2018 6:42 pm champs2018 Yes they can Grohe is sold everywhere. Just google the product code and send to your colou person to obtain a quote. The product code is standard regardless of the supplier Re: Building with Wisdom Homes 12689Sep 26, 2018 6:56 pm Manhattan52 @champs2018 Yes they can Grohe is sold everywhere. Just google the product code and send to your colou person to obtain a quote. The product code is standard regardless of the supplier Awesome..thank you Re: Building with Wisdom Homes 12690Sep 26, 2018 7:42 pm Did any of go with terracota rooftiles?? Is it worth the upgrade? I am confused if its good to upgrade or if colourbond or concrete rooftile is enough.. Re: Building with Wisdom Homes 12691Sep 26, 2018 8:07 pm champs2018 Did any of go with terracota rooftiles?? Is it worth the upgrade? I am confused if its good to upgrade or if colourbond or concrete rooftile is enough.. Yes I did. Paid 3000$. It will be good to expel the heat. Council approval 31/01/2018 Slab 26/03/2018 Outside Plumbing/electrical work done 05/04/2018 Frames started 09/04/2018 Re: Building with Wisdom Homes 12692Sep 26, 2018 8:10 pm Priyasuresh11 champs2018 Did any of go with terracota rooftiles?? Is it worth the upgrade? I am confused if its good to upgrade or if colourbond or concrete rooftile is enough.. Yes I did. Paid 3000$. It will be good to expel the heat. We did some research and choose the concrete tiles from monier and their c-loc tech had long lasting color. We would of sold the house before it fades. We didn't consider heat tho.Maybe it might reduce our basix costs as we had to upgrade to r5 insulation in the roof.. I need to look into that. Might be better value to upgrade the tiles Re: Building with Wisdom Homes 12693Sep 26, 2018 8:58 pm Priyasuresh11 champs2018 Did any of go with terracota rooftiles?? Is it worth the upgrade? I am confused if its good to upgrade or if colourbond or concrete rooftile is enough.. Yes I did. Paid 3000$. It will be good to expel the heat. Champs2018, we did too, and it was just under 3K. We just thought it was a better value at that price and looking at its properties vs concrete tiles... Maj-35 Tend:14/7/17,Cont:18/8/17,DA:9/1/18,DEP:1/2,Const:8/3, Slab: 28/3,Frames:17/4-23/4,Bricks:22/5-14/6,URoof: 29/6,elec:4/8,AC,GRoof:11/8,gyp:24/08,Keys:4/12,move:16/12 Re: Building with Wisdom Homes 12694Sep 26, 2018 9:03 pm stevezau Priyasuresh11 champs2018 Did any of go with terracota rooftiles?? Is it worth the upgrade? I am confused if its good to upgrade or if colourbond or concrete rooftile is enough.. Yes I did. Paid 3000$. It will be good to expel the heat. We did some research and choose the concrete tiles from monier and their c-loc tech had long lasting color. We would of sold the house before it fades. We didn't consider heat tho.Maybe it might reduce our basix costs as we had to upgrade to r5 insulation in the roof.. I need to look into that. Might be better value to upgrade the tiles I still have been asked to add R5 roof insulation for my West facing home. $2k upgrade. Supposedly the addition of a pool hindered the rating but ifso it will be ironic that ceiling insulation is the solution! I'm also looking to contact the Fryers Basix company to understand why. Need to find their number though. Re: Building with Wisdom Homes 12695Sep 26, 2018 9:11 pm Is it just me who thinks/feels like a variation 'In Lieu Of' really feels like you have just forfeited the 'included item' and you still are hit up with the 'walk in street price' of your preferred item? And how about the fee to have a 2nd colour! Re: Building with Wisdom Homes 12696Sep 26, 2018 10:12 pm GLO Is it just me who thinks/feels like a variation 'In Lieu Of' really feels like you have just forfeited the 'included item' and you still are hit up with the 'walk in street price' of your preferred item? And how about the fee to have a 2nd colour! Well we felt the same..we are charged 400 for using 2 colours for our facade. Any upgrade we make has an additional price to it but what happens to the original one that is given in standard..not sure if we would get credit or if the price for upgrade is over and above the price of standard.. Re: Building with Wisdom Homes 12697Sep 26, 2018 10:24 pm Yes I did. Paid 3000$. It will be good to expel the heat.[/quote] We did some research and choose the concrete tiles from monier and their c-loc tech had long lasting color. We would of sold the house before it fades. We didn't consider heat tho.Maybe it might reduce our basix costs as we had to upgrade to r5 insulation in the roof.. I need to look into that. Might be better value to upgrade the tiles[/quote]I have upgraded to the $3K Terracotta Plenum roof tile along with Bristle Solar Roof tiles too. I still have been asked to add R5 roof insulation for my West facing home. $2k upgrade. Supposedly the addition of a pool hindered the rating but ifso it will be ironic that ceiling insulation is the solution! I'm also looking to contact the Fryers Basix company to understand why. Need to find their number though. [/quote] Was the solar roof tiles added as an upgrade or was it included in the package?? Wisdom did not give us the live boldly promotion of $15k solar upgrade..not sure what is going to be the cost of it if we need solar added sepsrately as an upgrade..any idea?? Re: Building with Wisdom Homes 12698Sep 26, 2018 11:12 pm champs2018 Yes I did. Paid 3000$. It will be good to expel the heat. We did some research and choose the concrete tiles from monier and their c-loc tech had long lasting color. We would of sold the house before it fades. We didn't consider heat tho.Maybe it might reduce our basix costs as we had to upgrade to r5 insulation in the roof.. I need to look into that. Might be better value to upgrade the tiles[/quote]I have upgraded to the $3K Terracotta Plenum roof tile along with Bristle Solar Roof tiles too. I still have been asked to add R5 roof insulation for my West facing home. $2k upgrade. Supposedly the addition of a pool hindered the rating but ifso it will be ironic that ceiling insulation is the solution! I'm also looking to contact the Fryers Basix company to understand why. Need to find their number though. [/quote] Was the solar roof tiles added as an upgrade or was it included in the package?? Wisdom did not give us the live boldly promotion of $15k solar upgrade..not sure what is going to be the cost of it if we need solar added sepsrately as an upgrade..any idea??[/quote] It was part of my package during their campaign. It changes from time to time. Before this package they had a Tesla powerwall gen1 . This time I think they give you an option ie Wisdom Cash Re: Building with Wisdom Homes 12699Sep 27, 2018 6:51 pm Hubby sent me these pics today after a quick drive by after work. Our SS was onsite and confirmed he’s on track for mid October finish. I’m officially in love with my stairs! Aren’t they gorgeous! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Manhattan 52 Scrape 8/11/17 Slab 16/11/17 Handover 7/12/18 Re: Building with Wisdom Homes 12700Sep 27, 2018 6:55 pm amf139 Hubby sent me these pics today after a quick drive by after work. Our SS was onsite and confirmed he’s on track for mid October finish. I’m officially in love with my stairs! Aren’t they gorgeous! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Wow..they look awesome..we never knew such designs are an option with wisdom. They showed us only what was on display at canvas quarter.. Can someone please offer some advice? Im DESPERATE. Because I'm completely and utterly exhausted. How long are variations taking with other companies at the moment? We… 0 19536 In fairness nobody gave a crap about the ACCC and the gag clauses continued in the pro forma templates of a few other builders after the ACCC took on Wisdom, and more… 19 75206 Hi Everyone, I am exploring builder in NSW and received a very tempting quote from Wisdom home for their momentum series. I just want to know experience of building… 0 9867 |
