Browse Forums Building A New House Re: Who else is building with Eden Brae? 1201Oct 07, 2012 7:08 pm Speaking about costs, our family visited the Grand Designs Home Show in Sydney this weekend. We tried to get as many rough quotes as possible for similar things that we have asked for in our home, just to see if the EBH quotes have been fair. One of the expensive things that EBH want to charge for are the electricals. Downlights have been discussed in the past, but I was wondering if anyone tried to source the lights themselves, and then give to EBH to install? For those who have done their electricals, where is the appointment held? Is there an option to choose brands (e.g Clipsal)? Other interesting things we saw include artificial grass - never thought we would consider this option, but it appears very real with low maintenance. Oh and of course the $32k home theatre setup - worth 2x driveways ... Cheers, EBW Re: Who else is building with Eden Brae? 1202Oct 07, 2012 8:20 pm EBWaldorf- I thought about sourcing downlights and getting them to fit but it's approx $45 for them to fit each light fitting plus the wiring... It's easier to have them just fit and source the downlights. I am buying and having them install all the other light fittings though. Built a Hawthorne 31 with EB nessjeffdreamhouse.blogspot.com.au Building an investment now with New Living homes... We are at nearly finished... Just landscaping and driveway to go! Re: Who else is building with Eden Brae? 1203Oct 07, 2012 9:57 pm benblinkau kimmid benblinkau - We were quoted $4581 for Smoke/Nutmeg, $4,950 for Nickel Flash/Blue Steel Flash, $1,938 for Mild Steel/Loam & $934 for Gravel. I think Cement falls in the same category as Gravel so you should be up for around $1,000. What are your colour choices apart from the brick? Thanks for that!! Will b nice to know what to expect... Still unsure of what colour roof... Whether to go dark or light... Cement is pretty light... So we aren't quite sure... Woodland grey? Doin our flooring and HOG on friday! I think Woodland Grey would compliment Cement really well. We have decided on Monument. Just hoping that the colours are not categorised like everything else and what we want doesn't end up being an upgrade! Re: Who else is building with Eden Brae? 1204Oct 07, 2012 10:08 pm jencal sohnaeo sysbuild!!! Congratulations mate. Finally I paid $250 to Abbey Blinds, I got quotation from outside and negotiation with Abbey Blinds and they matched it. Only Advantage Blinds would be installed before you move in. I am getting simple Vertical and Roller blinds , it costs me around 3700$ for double story. Hi, we are also building a Lincoln (Monroe facade) at The Ponds. We are at the internal lining stage. We are also looking at having vertical blinds installed. Just wondering which rooms you are having roller blinds installed? We are having roller blinds in following areas Ensuite Bath WC Bedroom#2 Bedroom#4 Bedroom#3 Family Alfresco Stacking door Media Room Windows Who else is building with Eden Brae? 1205Oct 08, 2012 8:00 am kimmid benblinkau kimmid benblinkau - We were quoted $4581 for Smoke/Nutmeg, $4,950 for Nickel Flash/Blue Steel Flash, $1,938 for Mild Steel/Loam & $934 for Gravel. I think Cement falls in the same category as Gravel so you should be up for around $1,000. What are your colour choices apart from the brick? Thanks for that!! Will b nice to know what to expect... Still unsure of what colour roof... Whether to go dark or light... Cement is pretty light... So we aren't quite sure... Woodland grey? Doin our flooring and HOG on friday! I think Woodland Grey would compliment Cement really well. We have decided on Monument. Just hoping that the colours are not categorised like everything else and what we want doesn't end up being an upgrade! Does anyone know if colorbond colors are categorised? We have decided to go with mocha now! Re: Who else is building with Eden Brae? 1207Oct 08, 2012 9:41 am Benblinkau - All colours are available as standard as far as I know. EBW - Downlight charges are pretty standard across the builders. I looked into using my electrician to supply & install using his discounted rates after EBH have cut & prewired. It wasn't going to be that much cheaper but it would have been more of a hassle. Goodbye $12K! Kerith - Building an Eden Brae Newport 40 in Sydney's North http://kerithsedenbraehouse.blogspot.com.au/ Who else is building with Eden Brae? 1208Oct 08, 2012 12:13 pm Kerith Benblinkau - All colours are available as standard as far as I know. EBW - Downlight charges are pretty standard across the builders. I looked into using my electrician to supply & install using his discounted rates after EBH have cut & prewired. It wasn't going to be that much cheaper but it would have been more of a hassle. Goodbye $12K! Thanks mate! Good to know Re: Who else is building with Eden Brae? 1209Oct 08, 2012 12:15 pm We did the same Kerith, they are installing all of our downlights, and light fittings that I supply. Built a Hawthorne 31 with EB nessjeffdreamhouse.blogspot.com.au Building an investment now with New Living homes... We are at nearly finished... Just landscaping and driveway to go! Re: Who else is building with Eden Brae? 1210Oct 08, 2012 1:34 pm Did anyone else organise for extra noggins in the walls for artwork, mirrors, sports memorabilia (my husband has plenty from silent auctions!) etc etc? Anyone know what the cost is? If you look at our plans on my blog (tab up the top of home page), I am considering decreasing the width of the very wide square set opening to the main bathroom. Not sure what was going on there when the plans were drawn up. I am OK about no door but I think the vanity area is a little too exposed. Any thoughts from you learned peoples?! Kerith - Building an Eden Brae Newport 40 in Sydney's North http://kerithsedenbraehouse.blogspot.com.au/ Re: Who else is building with Eden Brae? 1212Oct 08, 2012 6:04 pm HoudaMan What down lights are EBH supplying? In our rumpus we are getting LED downlights that are able to be dimmed, they are a white fitting. In the kitchen we at getting LED downlights in a white fitting. We upgraded our laundry bunker light for a flood light. The upgrade was cheaper than buying said light, then paying for the fitting. All other lights I am finding at the cheapest possible price and providing for them to fit. They have a pretty good selection but you need to know your prices. Some are good value, but they weren't the fittings I wanted. The ones I wanted I knew I could get for cheaper including the fitting fee. EBH just supply one batten point and a switch and double PowerPoint for each room, as well as a bunker light outside the laundry door. Built a Hawthorne 31 with EB nessjeffdreamhouse.blogspot.com.au Building an investment now with New Living homes... We are at nearly finished... Just landscaping and driveway to go! Re: Who else is building with Eden Brae? 1213Oct 08, 2012 6:26 pm Does anyone know how much EB charge for the stencil driveway cross over? As standard driveway will have a plain concrete cross over. In my estate everyone got the stencil/paver driveway cross over, I thought it is standard. I sent an email to EB today for the confirmation, they said have to pay additional charges plus $500 admin fee for the late variation Re: Who else is building with Eden Brae? 1214Oct 08, 2012 6:33 pm [quote="sohnaeo"]Does anyone know how much EB charge for the stencil driveway cross over? As standard driveway will have a plain concrete cross over. In my estate everyone got the stencil/paver driveway cross over, I thought it is standard. I sent an email to EB today for the confirmation, they said have to pay additional charges plus $500 admin fee for the late variation /quote] We didn't have to pay anything more for our crossover. It was part of our included 55sqm... Would you have used your 55sqm inclusion? Built a Hawthorne 31 with EB nessjeffdreamhouse.blogspot.com.au Building an investment now with New Living homes... We are at nearly finished... Just landscaping and driveway to go! Re: Who else is building with Eden Brae? 1215Oct 08, 2012 6:38 pm 1sttimebuilding2012 sohnaeo Does anyone know how much EB charge for the stencil driveway cross over? As standard driveway will have a plain concrete cross over. In my estate everyone got the stencil/paver driveway cross over, I thought it is standard. I sent an email to EB today for the confirmation, they said have to pay additional charges plus $500 admin fee for the late variation /quote] We didn't have to pay anything more for our crossover. It was part of our included 55sqm... Would you have used your 55sqm inclusion? I didnt know 55sqm is the standard inclusion things are so complicated from where I can get 55sqm is standard inclusion? Re: Who else is building with Eden Brae? 1216Oct 08, 2012 6:46 pm sohnaeo 1sttimebuilding2012 sohnaeo Does anyone know how much EB charge for the stencil driveway cross over? As standard driveway will have a plain concrete cross over. In my estate everyone got the stencil/paver driveway cross over, I thought it is standard. I sent an email to EB today for the confirmation, they said have to pay additional charges plus $500 admin fee for the late variation /quote] We didn't have to pay anything more for our crossover. It was part of our included 55sqm... Would you have used your 55sqm inclusion? I didnt know 55sqm is the standard inclusion things are so complicated from where I can get 55sqm is standard inclusion? How long and wide is your driveway? Built a Hawthorne 31 with EB nessjeffdreamhouse.blogspot.com.au Building an investment now with New Living homes... We are at nearly finished... Just landscaping and driveway to go! Re: Who else is building with Eden Brae? 1217Oct 08, 2012 6:53 pm My driveway is 7.4 m long but not sure the width but cant be more than 5 m so definately it is under 55sqm, would it be mentioned in the contract or somewhere? They may say 55sqm for the driveway not included the cross over Who else is building with Eden Brae? 1218Oct 08, 2012 7:15 pm sohnaeo My driveway is 7.4 m long but not sure the width but cant be more than 5 m so definately it is under 55sqm, would it be mentioned in the contract or somewhere? They may say 55sqm for the driveway not included the cross over They wouldnt just leave your driveway half done and the crossover excluded.. Surely Re: Who else is building with Eden Brae? 1219Oct 08, 2012 7:22 pm They will just concrete your crossover, unless you tell them otherwise. Built a Hawthorne 31 with EB nessjeffdreamhouse.blogspot.com.au Building an investment now with New Living homes... We are at nearly finished... Just landscaping and driveway to go! Re: Who else is building with Eden Brae? 1220Oct 08, 2012 7:31 pm 1sttimebuilding2012 They will just concrete your crossover, unless you tell them otherwise. yes they asking me extra $$ for the stencil crossover otherwise crossover will be plain concrete. I built with EB back on 2009. Check out this thread on this forum. viewtopic.php?f=31&t=12911&p=154061#p154061 I can't speak for recent expericience however, we had no… 1 24125 A survey must’ve completed by a certified surveyor. This form part of every DA requirement 3 226378 |
