Browse Forums Building A New House Building a Sunnydale with Clarendon - weeks 34-38 101May 13, 2012 8:47 am The last two weeks have been extremely slow on site: save the gas company putting in the gas meter and the garage door (but not yet fully installed): more of that soon....could have been due to some bad weather and/or a change of site supervisor (due to Clarendon winding down operations in Melbourne)...who knows... What happened before then.... The Termiguard was installed...to protect the house against termites! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The garage roof got tiled.... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ with the lead flashing Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ and plastered on the inside Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Shower and toilet doors in the en suite were installed Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Well, the bench top finally got replaced! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ With the 2cm lip going around the bench and back bench. Yeah! There are going to have to do something about the tiling to the backbench now...but I am sure they will get onto it. And now for the garage doors.....(sign saying that it is still not fixed!) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ With a rear roller door Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Still not quite at "lock-up" nor "fixing" My Build:https://forum.homeone.com.au/viewtopic.php?f=31&t=50541&p=772361#p772361 site start: 24/8/11 slab: 5/9/11 frame: 21/11/11 lock-up: 6/6/12 Building a Sunnydale with Clarendon: weeks 39 - 42 102Jun 10, 2012 2:25 pm The past month has been a little slow going. Possibly due to getting a new site supervisor and him becoming familiar with all the issues involved with our particular build. We should now be fully on track now and we can get more progress happening. We finally got to lock-up with the last piece of the external being attached to the walls! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ and it is had the first coat of render (the second/colour coat is yet to happen) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The plaster sheeting under the garage eaves have been placed: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Then, unfortunately a day later, broke off, due to quite an extensive down pour Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ And fortunately, replaced again (let's hope this weekend's rain hasn't had too much of an effect!) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Inside the garage, some of the plaster has to be cut away to insert some noggins for the garage door motor Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ and unfortunately, a bit of mould has built up in the garage due to the rain and the garage roof not yet being sealed (due to the fact that there needs to be a second coat of render), which I am assured will be replaced. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ One of my concerns has been a bowing above a window in the master bedroom. They have already ripped off the cornice and attempted to pack between the top plate of the frame and the trusses. Still not good, they are having a second go at it (persistence does count sometimes) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ On initial viewing, the ceiling is looking a lot better. We will see when they put the new cornice on! There has also been some sanding of the stair balustrade, adjustment of hinges and even the first internal house clean! (Apparently, the house gets about 4 cleans before hand-over!) Not a long way to go now! My Build:https://forum.homeone.com.au/viewtopic.php?f=31&t=50541&p=772361#p772361 site start: 24/8/11 slab: 5/9/11 frame: 21/11/11 lock-up: 6/6/12 Building a Sunnydale with Clarendon - weeks 43 - 45 104Jul 01, 2012 2:48 pm It's now into the little bits and pieces time, where not a lot seems to happen and the little bits seem exciting! The electricians have been around doing some more installations: Outdoor light fittings and power points Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ And some indoor fittings and exhaust fans: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Some of the brickwork around the front door has been redone, due to the brickwork not being good and lining-up to begin with: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ In-fills over the doors have been installed: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Part of the fence has been rebuilt: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ New tiles have been delivered to replace the job (which wasn't so good) previously done on the previous feature tiles: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ And, the temporary fence has gone! I can now have an unobstructed view of the front of the house: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Still little bits and pieces to go...like installing the kitchen sink and redoing a few of the internals. Yes, patients is important! My Build:https://forum.homeone.com.au/viewtopic.php?f=31&t=50541&p=772361#p772361 site start: 24/8/11 slab: 5/9/11 frame: 21/11/11 lock-up: 6/6/12 Building a Sunnydale with Clarendon - week 46 105Jul 08, 2012 9:28 pm Fairly busy week on site with plumbers, plasterers, tilers, electricians and even an auditor! The final basin and kitchen sink was finally fixed and fitted Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ This means we are finally at 'fixing'...now just waiting for the bill to arrive! The tap is going to be replaced with a vegie sprayer...but apparently this occurs at completion. We had some heavy rain over the previous weekend and the storm water outlet overflowed. Speaking with the site supervisor, he suggested there was a blockage between the outlet and the barrel drain somewhere in the street. Getting my plumber there to investigate the problem it was soon found...the storm water isn't connected! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Just something else they need to sort out! The feature tiles around the basins (which were shocking) and the tiles around the kitchen (which were too short) were cut out... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ and replaced with new tiles after being re-plastered Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ and just because I like the look of the place Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ My Build:https://forum.homeone.com.au/viewtopic.php?f=31&t=50541&p=772361#p772361 site start: 24/8/11 slab: 5/9/11 frame: 21/11/11 lock-up: 6/6/12 Re: Building a Sunnydale with Clarendon 106Jul 13, 2012 11:20 am Hi katman, Loving the pics. I too will be building the sunnydale, but am still at the initial stages of designing the house. I have noticed you have made heaps of changes to the original sunnydale, some of which I have added to my design Thanks to your blog I can get a sense of timeline. Do you have any tips to share? And did you get any "freebies" included in your contract? Building a Sunnydale with Clarendon 107Jul 16, 2012 8:35 pm Thanks Kelli. In terms of things to add, there is a great page "things you forgot" http://forum.homeone.com.au/viewtopic.php?f=31&t=5823&hilit=things+you+forget Know your contract inside and out. Get to know your drawings because once you sign off, everything goes by the contract, right/wrong or otherwise. If it is in the contract, they have to do it. If it is not in the contract, or incorrect in the contract you can be stuck with it, without a variation. Understand the little details like an overhang, a lip over a bench, tiling drawings does the downstairs have eaves or not, are lights in the right spot etc....double and triple check everything. Go to the Consumer Affairs website (or equivalent in your state) and understand your rights and stage payments. http://www.consumer.vic.gov.au/housing-and-accommodation/building-and-renovating/buying-and-building-process Get on site as much as you can. Measure things up with your tape measure and spirit level (particularly the frame) and have someone in the know come and check. Meet the tradies where you can, particularly the electricians to make sure the power points and other stuff is in the position where you want them to be. Go to the Building Commission website (or equivalent in your state) and download the "guide to standards and tolerances". http://www.buildingcommission.com.au/resources/documents/S+T_GUIDE_07.pdf There weren't really any freebies (I don't think that there really are freebies!), but I do recommended that you take the upgrade packages. They are usually good value. My Build:https://forum.homeone.com.au/viewtopic.php?f=31&t=50541&p=772361#p772361 site start: 24/8/11 slab: 5/9/11 frame: 21/11/11 lock-up: 6/6/12 Re: Building a Sunnydale with Clarendon 108Jul 20, 2012 11:08 am Thanks so much for the link Hoping to get plans back in the next few days, and then be on the way to building too Do you have any pics of your walk in robe? Are you outfitting it yourself? I'm not convinced still of the standard Sunnydale 3 door sliders (standard) and was just curious as to your design... Building a Sunnydale with Clarendon 109Jul 25, 2012 10:04 pm I don't really have many pics of the robe, except for the one a few pages back. It is a walk-through robe, based on the display home Clarendon had, rather than standard robe that you see in their standard plans. I have posted a copy of the plan back on page 1. It isn't a standard room, with bulk heads and air-con voids going through it. We decided to get a few wardrobe people to measure and quote and give ideas about how they would fill the space. After that we decided to go with Stegbar. Their sales guy had the best ideas in terms of functionality of the space and whilst not the cheapest (even though close) they appear (on paper) to represent the best value for money. We will see if all that is true once they install the robes after handover! My Build:https://forum.homeone.com.au/viewtopic.php?f=31&t=50541&p=772361#p772361 site start: 24/8/11 slab: 5/9/11 frame: 21/11/11 lock-up: 6/6/12 It is Genneral stairs, but they won't deal with anyone off the street. They will only work with clients of project home builders. I tried to but some of these exact… 3 8073 The two 15mm holes are obviously not compliant. The Dept of Fair Trading would love to see this one! Do the gutters pool water after it stops raining? Although it's… 4 8404 |
