Browse Forums Building Standards; Getting It Right! 1 Jun 26, 2020 5:00 pm Hi, We are in whitehorse. and we have this situation for knockdown rebuild where our house is in middle and have a porpety on left and right which face other street. Property on left has enterance and faces court street although thier postal address is same street as ours. Property on the right faces the other street and their main entrance is on that street. So that leaves us in middle using and facing the street. I am trying to find out what set back to expect , our block is 34 x 16. I looked up some info on vic planning There is no existing building on either of the abutting allotments facing the same street, and the site is not on a corner. >> 6 metres for streets in a Road Zone, Category 1, and 4 metres for other streets. Does this mean we can go as close to street as 4 meters ? it's a quite street. so not the road zone 1 I believe. Any experts there would know , we have to choose design based on what set back to expect. Re: Front Setback unique situation 4Jul 01, 2020 11:33 am Thanks Pulse. Council it's hard to get any response other than standard responses. I guess I will have to signing up with some builder and then go from there. After all the failed attempts I can't find real setback to expect. Thanks Draftroom that definitely helps a heap. We are still at the very early stage of planning to see what kind of house would fit on our plot. While we are on a… 3 15766 You might be able to apply to divert the sewer at your expense. In NSW you would contact a Water services co-ordinator and they would give you advice as to whether or not… 1 16145 Hi All, see above image. The required setback from the rear boundary in my case is 5m, as you can see the shape of the site and location of the boundary is slightly… 0 8451 |
