Browse Forums Building Standards; Getting It Right! 1 Jun 24, 2020 2:25 pm We live in an apartment, ground floor unit with a backyard. I have my own hot water service on the external wall and next to it is my neighbours. It was built like this and it is in the architectural drawings. Is this compliant with the building regulations? Re: neighbours hot water service on my side of the backyard 3Jun 29, 2020 11:59 am Sorry I didn't clarify. We have our own backyard which is separated with by a fence. So shouldn't his HWS be on his side of the fence? It is also connected to a GPO which I am not certain who it belongs to. And when he requires maintenance on it, he would have to come through my apartment? Re: neighbours hot water service on my side of the backyard 6Jun 30, 2020 6:19 am that’s a bit unusual, no fence shown on the plans, I think you need to clarify what is on your title, I assume it is strata. Your conveyancer should have the strata plan which should show if the yard is common property or your property. otherwise fence off the HWS with a gate access from each property Thanks for the photos. You need to know whether the inflow or the overflow pipe is leaking and this is a simple process of elimination. INFLOW: The vertical riser… 4 4674 the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14039 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20230 |
