Browse Forums Building Standards; Getting It Right! 1 Apr 06, 2020 9:57 pm Can you generally install a veranda and fasten it to brick veneer wall if it is supported by posts opposite? I've recently finished building 2 new houses in a sub division and want to install verandas to them but not sure if I should definitely go free standing or the type that fastens to the back of the house. Re: Veranda onto brick veneer 2Apr 07, 2020 8:38 am Either way you will require a planning application (DA) Once received the structural and construction Details are dealt with at the next stage Building Application (BA) Your local Council should have a building checklist BTW photos help others, generally the better the information the better the reply hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Veranda onto brick veneer 3Apr 30, 2020 3:08 pm StructuralBIMGuy Either way you will require a planning application (DA) Nope Completely depends on the locality and planning scheme. E.G In Victoria it would only require a planning application if it encroached on a minimum set back or if the allotment size was less than specified in the schedule. i think option 2 is much better with easy access to the garden without having to walk through the new sunroom which makes it a better room for guests and TV .a simple… 2 8230 There may be answers here but can't find anything. I have a closed in veranda, four windows. North facing, just had sunblock blinds installed. A bit cooler (actually… 0 2981 2 8359 |
