Browse Forums Building Standards; Getting It Right! 1 Sep 03, 2019 9:29 pm Hi All, I'm looking at extending 2 bedrooms, laundry and bathroom out to the eaves. What I am unsure about is the plumbing and waste services. It appears that the waste goes straight down the side of the house and follows along the length of the wall about 50mm parallel to the edge of the house. Is it okay to extend the slab over this? Or will it have to be moved. It's a clay pipe. Hope that makes sense. Thanks in advance! If your patio is going to be 35 sqm then that's going to need Council Approval. The fact that they previously approved your 25sqm patio will be irelevant 1 5693 Ask for some kickplate to be added and also for tradies to be requested to use lanyards on tools on that side of the building. Be respectful and have the discussion… 1 1791 There is insufficient information to give a meaningful answer. You should talk to council planning. Apart from building construction issues, if you are adding floor area… 1 8364 |
