Browse Forums Building Standards; Getting It Right! 1 Aug 06, 2019 12:36 pm Hi All, I need some assistance on identifying if this is an issue or not. We had our place built 8 months ago and I have noticed that in some areas the timber laminate flooring can be pushed down to create a gap between the flooring and the skirting board. I basically want to know if this is normal and within tolerances if anyone could assist. If it's not normal is anyone able to explain what they believe the be the cause of the issue (for example – floor not level). I can confirm there is underlay. Can you please have a look at the video link and provide some feedback please – https://imgur.com/a/wj7e0JJ Cheers. Re: Timber Laminate Floor Sinks in Corner of Room 2Aug 07, 2019 7:48 am Hi koolmoedee Welcome to the forum and thanks for the (Simulation) video Did you take photos or videos during the build, have staged inspections,etc,etc? Unfortunately it's too early to start speculating without data and proof You will need to monitor the changes in movement (mm) over time.. precisely, ie cracking, deflections,etc WA Guide To Standards and Tolerances Ideally, I would have recommended prior to installing any finishes 1. Checking Room Dimensions (XYZ) Coordinates with Bosch Laser 2. Checking Wall & Floor Building Tolerances with Bosch Lasers Please post back if have have further questions as it also helps others as well Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Timber Laminate Floor Sinks in Corner of Room 3Aug 07, 2019 8:21 am Most likely cause is that the floor is not level. With my recent Metricon build the slab was not level. Knowing the importance of a level slab for floating floors I used a laser and 2m straight edge to check it. I insisted they level the floor, which they did by employing a specialist floor levelling contractor. Checked it again and it was suitably level for the floating floor. Re: Timber Laminate Floor Sinks in Corner of Room 4Aug 07, 2019 10:31 am Norfolk Most likely cause is that the floor is not level. With my recent Metricon build the slab was not level. Knowing the importance of a level slab for floating floors I used a laser and 2m straight edge to check it. I insisted they level the floor, which they did by employing a specialist floor levelling contractor. Checked it again and it was suitably level for the floating floor. I agree with this, I have seen laminate layed on uneven concrete and it does what you describe During my build my inspector checked and picked up that the concrete was not perfectly level in some sections. Before laying the floor the builder had someone come in who ground some sections and filled others to make it perfect (They said they always do this anyway as the concreters don't get it perfect) Hi, We're building a double-storey in Perth and I'm undecided with the kitchen sink situation. I'm set on having the main sink with dishwasher in the scullery - and… 0 20938 4 14309 Dear all, Requesting your help in relation to a CDC code. We are building a new home in NSW on a corner lot (500m2, 15m wide) following Greenfield CDC code. Our design… 0 4788 |
