Browse Forums Building Standards; Getting It Right! 1 Aug 05, 2019 10:07 am Here is an accurate, easy and quick way to measure, survey and check room dimensions or coordinates Using the Bosch GLL 3-80 CG Professional 3-Plane Green Laser and Bosch GLM150C Laser Rangefinder This is the first step in collecting Data for determining and assessing Wall, Slab and Ceiling Movements hth Checking Suspended Floor Deflections With Bosch Laser Tool Checking Wall & Floor Building Tolerances with Bosch Lasers Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Well, it was the default we got with our deign, walking through the build last week felt ok, based on drawings on the floor, it is basically a metre, which is quite a big… 3 1834 I am installing a new Bosch SMU4HTS01A built under dushwasher. I have 2 questions. What is the function of the metal strip about 500mm long x 60mm wide the tell you to… 0 3211 sorry mate, not wasting more time on this. Youve completely missed the mark on some fundamentals and regardless of how many times i try and put it to you differently, you… 11 10990 |
