Browse Forums Building Standards; Getting It Right! 1 Jul 12, 2019 9:34 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Any thoughts on excessive gap between flooring and sliding door of bathroom. Does this meet compliancy with building code? Is there a particular reason why gaps under doors are supposed to be of certain height? Thoughts and reason would be appreciated? Would you accept for a brand new build? Re: Excessive gap between tiled floors in bathroom and cavit 2Jul 13, 2019 9:32 am I’m not 100% sure on tolerances etc for this, but funnily enough we originally in our plans had specified minimum 20mm gap for toilet and bathroom door gaps to allow better air supply for the exhaust fans in those rooms! In the end we removed this, as the builder said there would be at least 10mm gap anyhow. When we built with a larger volume builder 10 years ago, they installed decent brush type seals on the backs of our bathroom doors (though not CSD type). I reckon you should be able to get seals for your CSDs in these particular areas. So although 25mm does seem excessive, my thoughts are not a massive issue. You could ask if they could adjust the CSD down a bit, then request proper door seals be installed as well. --------------------------------------------------------------------- Check our Homeone build blog here Re: Excessive gap between tiled floors in bathroom and cavit 3Jul 13, 2019 3:19 pm If you have ducted air, the gap is probably there to allow air to go back to the return air of the ducted system. Re: Excessive gap between tiled floors in bathroom and cavit 4Jul 14, 2019 11:13 am darb74 I’m not 100% sure on tolerances etc for this, but funnily enough we originally in our plans had specified minimum 20mm gap for toilet and bathroom door gaps to allow better air supply for the exhaust fans in those rooms! In the end we removed this, as the builder said there would be at least 10mm gap anyhow. When we built with a larger volume builder 10 years ago, they installed decent brush type seals on the backs of our bathroom doors (though not CSD type). I reckon you should be able to get seals for your CSDs in these particular areas. So although 25mm does seem excessive, my thoughts are not a massive issue. You could ask if they could adjust the CSD down a bit, then request proper door seals be installed as well. Thanks for the idea and options avail. If adjust down, then would see more of rollers and gap above. At moment as it stands, the track above is visible now. 2 7481 How good is Simeon?! Always taking time to help others out! Wish we were building in NSW and could work together. Thanks for all that you do! 7 6550 Old Home Restoration / Renovation To reduce noise transfer without compromising the aesthetic of your exposed I beams, consider filling the 100mm gap between the I beams and the floor above with dense,… 6 9112 |
