Browse Forums Building Standards; Getting It Right! Re: Load baring double and triple studs 2Jun 28, 2019 7:50 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Load baring double and triple studs 3Jun 28, 2019 10:39 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Load baring double and triple studs 4Jun 28, 2019 11:09 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Load baring double and triple studs 6Jun 28, 2019 12:52 pm Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Load baring double and triple studs 8Jun 29, 2019 7:49 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Load baring double and triple studs 9Jun 29, 2019 9:39 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Load baring double and triple studs 10Jul 01, 2019 7:54 pm It seems unusual for studs to be continuous from ground to 1st floor framing. Could understand a bit more if they were calling for steel. The practicality of this scenario onsite is bizarre. Having 5m+ studs in a ground frame, bracing/plumbing till you get to the 1st floor plus lots of other things about this. There’s the connections to top plate butting into the stud? Do they want studs under top plate each side of the double/triples? Or skew nailed sufficient with triple grips/hoop iron or the like for uplift? Bit of head scratching in my opinion and the carpenter hasn’t said anything incorrect at the moment. Any structural alteration to your home requires building permit. Before you get it you will have to supply plans with structural assessment, you will also be removing… 2 4121 I’m in a similar position except I’m after sliding 3 stacking doors. I am on a second-story apartment of which the balcony would not adequately fit any bi-fold or… 5 16153 Current door width is approx 2700, looking to have double doors fitted 820-820. What size does the frame need to be before door jamb? Thanks 0 3548 |
