Browse Forums Building Standards; Getting It Right! Re: Roof flashing not built into brickwork??? 2Jun 28, 2019 12:28 am chanam Is roof flashing (wakaflex) installed correctly to meet water tightness of building? Concerned with rain hitting the brick wall and down the back of flashing. The adhesive over time will degrade allowing ingress of water. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Roof flashing not built into brickwork??? 3Jun 28, 2019 10:43 am The flashing fixing detail is not compliant, contact plumbing commission if you are in vic Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Roof flashing not built into brickwork??? 4Jun 28, 2019 11:39 am building-expert The flashing fixing detail is not compliant, contact plumbing commission if you are in vic Thank you for your valuable input. Much appreciated. Just thought i put out there as have had experience in huge tropical storm whereby horizontal rain penetrates into building. Re: Roof flashing not built into brickwork??? 5Jun 28, 2019 1:03 pm The other problem you have is if there is another weep hole to the right of photo 3 it will be behind flashing and leak Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Roof flashing not built into brickwork??? 6Jun 28, 2019 4:07 pm I have some done like that on my house (against render though, not brick) and Darbecca accepted it. (They picked up other non-compliant flashing) Re: Roof flashing not built into brickwork??? 7Jun 28, 2019 8:51 pm building-expert The other problem you have is if there is another weep hole to the right of photo 3 it will be behind flashing and leak Fortunately, there isn't a weep hole behind flashing (after checking photos of pre-flashing instal. Re: Roof flashing not built into brickwork??? 8Jun 28, 2019 8:56 pm brokenstick I have some done like that on my house (against render though, not brick) and Darbecca accepted it. (They picked up other non-compliant flashing) Apparently it seems like a normal practice these days as I have seen some like that on rendered wall also and so I have been told also. Wonder how this would stand if making insurance storm claim for water damage.🤔 Re: Roof flashing not built into brickwork??? 9Jul 01, 2019 7:25 pm As building expert mentioned the flashing isn’t compliant. You can check and use this as a minimum guide and look at the wakaflex install notes and it states it should be chased into the brickwork and/or over flashed. In my view it should be over flashed no matter what. Re: Roof flashing not built into brickwork??? 10Jul 12, 2019 7:51 pm This isn’t compliant to the manufactures requirements, this is how it is meant to be installed http://wakaflex.com.au/installation.html Re: Roof flashing not built into brickwork??? 11Jul 12, 2019 8:52 pm chanam chanam Is roof flashing (wakaflex) installed correctly to meet water tightness of building? Concerned with rain hitting the brick wall and down the back of flashing. The adhesive over time will degrade allowing ingress of water. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Update of fixing... Point 1 - is the after fix photo of roof flashing. Is this now compliant to meet code? Point 2 - should gap between brick and linea board be sealed to meet code? Re: Roof flashing not built into brickwork??? 12Jul 13, 2019 9:58 am Lol no, what’s the difference from this and before except for a piece of metal cover? I know this post is from a while ago, but the VBA has some good guidance on this. https://www.vba.vic.gov.au/__data/asset ... 5-Roof.pdf 2 10718 Cheers. The painted render is a bit chalky to the touch. To prepare the surface for best adhesion, what would you recommend? Also, given that there must be some… 6 8647 I am in the same situation, would you be able to give some insights in to this? I am in SA 8 17095 |
