Browse Forums Building Standards; Getting It Right! 1 Jun 27, 2019 4:33 pm After receiving requests recently on How to check if walls are plumb and square and slabs are flat and level Here's an illustrated method using The Bosch GLL 3-80 CG Professional 3-Plane Green Laser That's Quick, Accurate, Easy to set up, that anyone can use ie, Tradesman,Engineers, Builders ,Building Surveyors, Owner Builders,etc I consider it a must have tool on any build, other uses Checking Suspended Floor Deflections With Bosch Laser Tool Checking Room Dimensions (XYZ Coordinates) With Bosch Lasers hth Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Checking Wall & Floor Building Tolerances with Bosch Las 2Jul 20, 2019 11:45 am Here's an example of how how out of square external Walls (out by 100mm) which were not checked on site AS-Built against the drawing dimensions (data). These errors then translate to the roof as redesigns with non conforming split Roof trusses Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Checking Wall & Floor Building Tolerances with Bosch Las 3Jul 20, 2019 11:55 am the dewalt is more accurate https://www.laserlevelhub.net/dewalt-laser-level-vs-bosch-laser-level/ Re: Checking Wall & Floor Building Tolerances with Bosch Las 4Jul 20, 2019 12:02 pm aussieta the dewalt is more accurate https://www.laserlevelhub.net/dewalt-laser-level-vs-bosch-laser-level/ LOL, Based on what an opinion/advert...engineering requires DATA, PROOFS and applications. hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs I am installing a new Bosch SMU4HTS01A built under dushwasher. I have 2 questions. What is the function of the metal strip about 500mm long x 60mm wide the tell you to… 0 1782 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 11031 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 12656 |
