Browse Forums Building Standards; Getting It Right! 1 May 03, 2019 3:29 pm We are in preparation for raft slab and concretor had put the pipe laggings only on horizontal and bends. He is saying there is no lagging required for the vertical pipes even its under the beam. Is this correct? What is the best practice ? yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7331 Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4873 I think you are getting different numbers because they all just based them on "other jobs" even though each job is unique. Often, with builders, unless you're speaking to… 3 3242 |
