Browse Forums Building Standards; Getting It Right! 1 Apr 27, 2019 4:13 am Our engineer specified tensioned strap bracing in a cross for the stud walls. Our carpenter used a single diagonal angle brace instead, notched into the frame. The engineer said bracing must be in a cross. It’s too late to replace the angle bracing as the timber has been notched, and too late to redo the stud walls. Angle bracing can’t be crossed because the brace would have to be trimmed to sit flush at the cross section. Could we brace the other side of the stud wall with strap bracing as per engineering? Any other possible solutions? Re: Wrong bracing used, can other side of stud wall be brace 2Apr 27, 2019 9:11 am Yes you can brace the other side of the stud wall Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Hi all, Not sure if this is a good place for this question but I guess we'll find out! I'm a novice, building a modular room inside my garage/shed and need to create… 0 1448 there is only 20% difference in concrete strength between 20 mpa and 25 mpa, so check with your engineer first if it fits his calculation tolerances. There are ways to… 6 14610 Hey everyone Not for me or anyone I know, just generally interested. For a single allotment house, are you allowed to take the fence on both sides of your house and… 0 15388 |
