Browse Forums Building Standards; Getting It Right! 1 Feb 28, 2019 3:33 am Brickwork have just been high pressure cleaned. The mortar looks very soft sandy and weak. The sands crumbles down if you run your finger on the mortar. Here is the video https://youtu.be/rL-NTP3Pe4Q Have everyone had the same issue and can advise what are the possible remediations? Thanks in advance. Re: Mortar defects? 2Apr 13, 2019 11:26 am Here is info on Mortar Test Results and some Dos and Don'ts Do check the mortar composition and if any additives are added then don't use a water pressure cleaner You will probably have to Repoint Brickwork at a later stage Goodluck Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6895 1 9464 All 3 items listed are defects and are of concern. Please seek qualified independent inspector and/or legal advice for your state. 1 8203 |
