Browse Forums Building Standards; Getting It Right! 1 Sep 14, 2008 7:37 pm Hi All,
I have a question regarding the PVC storm drainage for our home. On the blind side of the house it doesn't seem as they've buried the PVC deep enough. The PVC is at the same level as the bricks. Is this a breach of builder practices and plumbing regulations? I've posted a few pics on my blog... Would appreciate some advice... Thanks Re: Storm Water Drainage 2Sep 14, 2008 8:23 pm The stormwater isn't generally too far below the surface - the main thing is it runs off onto the road etc. Re: Storm Water Drainage 3Sep 15, 2008 1:39 pm is there any specific regulations that the work needs to comply with? Re: Storm Water Drainage 4Sep 15, 2008 7:03 pm I imagine it varies from council to council.
I'll have a look in the Building Code Re: Storm Water Drainage 5Sep 16, 2008 9:10 am Hi All,
I just got an email back from our Home Inspector Kevin, and he's basically saying there is a requirement for builders to ensure that the drainage to set to a suitable depth for paving and concrete. At least now I can rest at ease knowing Kevin will surely pick this up... Thanks again Duke, would be great for others that are building to know this as well...defintely will save a few PVC pipes before the bobcats go over them... PaPs... Re: Storm Water Drainage 7Sep 17, 2008 1:52 pm under soil 100mm
under paved or concrete area 50mm under areas subject to light vehicle traffic reinforced concrete -75mm paved - 100mm no council to council regs comes straight out of building code Hello I am developing 2 side by side units. Wish someone can help me on the following questions 1) Which stage should be the storm water pipe installed during the new… 0 7809 If you need to be able to access these then you may need to dig them out and cut them so you can add a socket and a riser to the required height. We normally add a… 1 6842 Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 10466 |
