Browse Forums Building Standards; Getting It Right! 1 Jan 19, 2019 8:37 am Hi Guys I am renovating my pool area and I might have a dispute on how the landscaper has screwed the hardwood to the feature wall and also the customer made seat they are doing. Issue Everyone I have spoken to after the event has said to avoid warping and cupping two screws should be used. As per the picture the landscaper has only used one and after only two weeks (they haven’t finished the job yet due to Xmas) some boards already have visible cupping. When I questioned the landscaper why he only used one when I had received advice that two is standard he said that Hardwood under 100 ml only needs one screw. Question. Does anyone know if there are any standards for how many screws are required for hardwood. Our boards are 90 ml. I want to be able to have a reasonable discussion with him. He as suggested he could do more screws but having 3 screws on a 90ml board is overkill and my preference would be for him to start again and build to standards required. Many thanks Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Wooden boards screwing standards 2Jan 23, 2019 12:55 am Hi Duke The link below pertains to building decks. Section 1.5.2 details fixing with nails and AS specify 2 nails per board per joist. Section 1.5.4 talks about screws and states that the same principles should be followed. Your issue may be that your not dealing with a deck but screens and the landscaper may try and use this as an out. Simply put, it's very poor construction and no decent chippy would ever think of fixing of decking, screens or seating like that. You always use 2 screws. The board's will cup and look horrible in a very short amount of time. They haven't even countersunk the screw heads flush with the board. Link: https://www.google.com/url?sa=t&source= ... 8164412036 Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Wooden boards screwing standards 4Mar 29, 2019 8:07 am The information the landscaper has given you is incorrect. Australian Standards stipulate 2 screws per board/joist Ideally you should be staggering the fixings as well - more of an issue with nails, however we also do it with screwed decks. the reason being that when you install the fixing it creates a little split in the joist and water tends to sit in there. This split gradually increases and more water sits and rots it out until eventually the fixing no longer holds and the boards pop up Two other things to consider to get better life out of your deck 1 - Always paint your joists out with an exterior sealer 2 - Always use a rubber rubber joist protector. these sit on top of the joist and shed water off the top. they also create a seal around your mechanical fixing Your deck will absolutely start cupping with only one screw - Out of curiosity - did you check the landscapers license details at all before engaging him? That would be a hard landing, a lot worse than the Iceland ones. 25 5823 ![]() Building Standards; Getting It Right! I suggest you use /provide proper certified details to the carpenter/builder Rather than rely on what he offers or tells you. That way you will avoid non compliance and… 3 1953 ![]() There’s a wooden feature on the outside of my house, that I can’t reach (even with a ladder). So I was thinking of getting something like 0 1669 |
