Browse Forums Building Standards; Getting It Right! 1 Dec 11, 2018 12:09 pm Hi all, I'm in Bracken Ridge and planning a DIY deck build . I'm trying to ascertain please what the requirements are for footings for 1) ground level deck 2) patio cover (similar to basic flat stratco style with cooldeck panels) I want to construct proper footings for the roof, at the same time as building the deck, so it's much easier to do the roof later. So how can I find out what type/depth/size footings are required or both a ground level deck and a patio roof please? Also are there any particular standards around decking materials, joist spacing etc ? I'd assume appropriate treated pine for poles/bearers/joists, with the poles set in stirrups bolted to concrete footings, 450 centres for joists etc. Unless something has changed around standards? I might add that the Brisbane City Council website is both hard to navigate and doesn't seem to have this info. Plus their 'planners / engineers' IF they call back generally take about a week to do so.... Re: Deck standards esp re footings ? (Brisbane) 2Dec 13, 2018 11:58 am Landyvlad You might find this useful on Timber Decks Projects to do after handover Alternatively search my Structural BIM images, post back or leave a PM Cheers Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Deck standards esp re footings ? (Brisbane) 4Dec 17, 2018 7:37 pm Unfortunately,That is a useless Jpeg Image file which is all I'm able to put up For more detailed information I use PDFs for details, G-sheets for Quantities, Planning,etc Tied into suppliers codes, prices and more What specific magnified part/detail/info do you require? Timber deck Quants? Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 7012 I believe this is correct. From the picture you can see the power was put in last so the electrician knew where the water was. Really it's a common sense issue more… 4 5159 2 8647 |
