Browse Forums Building Standards; Getting It Right! 1 Nov 19, 2018 7:58 pm I recently had a concrete apron done around the house. But the concreter has not put a Ableflex layer between the house and the concrete. Is this really necessary? I'm concerned about water running between the concrete and the wall causing problems to the structure. The soil is class P. Thanks Re: Is Ableflex a must when doing a pavement around the hous 2Nov 19, 2018 8:58 pm No not necessary. Concrete to concrete should be fine, if you are worried about gaps, ask him to put sealant there gaps. Should be OK. Don't stress. Re: Is Ableflex a must when doing a pavement around the hous 3Nov 19, 2018 9:00 pm It isn't a regulatory requirement but it is a good idea to have it. https://www.cornellengineers.com.au/all-about-abelflex/ You can get other products, Selleys have a filler that is often used. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. I have stone pavement (?) in my backyard around the pool. I have not tended to them and so there is moss growing on them. I intend to clean them but was wondering what the… 0 1910 The DIY project can be broken into two major steps. Planning and Design and Construction. Both of these steps are as important as one another to ensure you give… 0 5229 Hi group, have some damage to the door frame and skirting board. It's a side door to the laundry area. Only has a security door. I had a termite inspection (note drill… 0 5131 |
