Browse Forums Building Standards; Getting It Right! Re: Storm water 61Feb 20, 2020 10:21 pm Good luck with it all. You are well armed and I hope that rectification doesn't cause too much disruption. Connecting the second overflow won't be a problem. There were posts on another thread on H1 not long ago where a person was in his new home for 3 years before finding out that his rainwater harvesting system didn't have a pump or a mains water switching device fitted and yes, he had paid for them. viewtopic.php?p=1861218#p1861218 A few years ago I replied to a guy who couldn't get his pump to pump water from the tank. A plumber had installed the system. The photo below shows why the pump wouldn't work. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ If you didn't see some things, you would never believe them. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Hello I am developing 2 side by side units. Wish someone can help me on the following questions 1) Which stage should be the storm water pipe installed during the new… 0 7834 If you need to be able to access these then you may need to dig them out and cut them so you can add a socket and a riser to the required height. We normally add a… 1 6857 Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 10484 |
