Browse Forums Building Standards; Getting It Right! Re: Engineered solutions 10Oct 02, 2018 8:47 pm Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Engineered solutions 13Oct 02, 2018 10:58 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Engineered solutions 15Oct 03, 2018 8:36 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs In the end, two pieces of treated timber (20mm thick) were bolted onto the joists and planed when there was too much sticking out. Passed inspection. 13 7851 I would find out how deep your clay base is and depending on the depth install a cut off drain which is more than a normal agi drain. Where the neighbouring walls is… 2 3165 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15994 |
