Browse Forums Building Standards; Getting It Right! DIY, Home Maintenance & Repair could be the footing or being hard up against the other wall with no expansion joint or both. You could try again with brick mesh and use some sticky back foam against the… 1 1107 You might be able to apply to divert the sewer at your expense. In NSW you would contact a Water services co-ordinator and they would give you advice as to whether or not… 1 16185 do not pay until you are satisfied with workmanship windows require flashing over the head archithrave and up under weatherboards 3 28324 |
