Browse Forums Building Standards; Getting It Right! 1 Jul 14, 2018 12:40 am Hi, I am reading the following Clause from the NSW CDC guidelines: Clause 3.12 (3) Maximum area of attached balconies, decks, patios, terraces and verandahs setback from side or rear within <6m; and with a floor level >2m above ground : 12m² The above guide is for balconies less than 6m from any boundary AND above 2m above natural ground level. My question is: If the balcony is greater than 6m from all boundary, can you build a larger than 12m² balcony? Thanks in advance. Re: CDC Clause question. 2Jan 21, 2019 1:19 pm Hi GLO, I know it has taken a long time for someone to respond but hoping at least someone might get something out of this reply. You are correct that if can build a balcony larger than 12sqm under CDC if the balcony is greater and 6m from the boundary. The clause only provides a limit if it is within 6m AND over 2m off natural ground level... therefore if one of them doesn't apply to your development then the size restriction doesn't apply. The Exempt and Complying legislation is very difficult to read sometimes and it is often a process of elimination. If you have any further questions on anything CDC or Planning send us a PM. Re: CDC Clause question. 3Feb 10, 2021 8:28 pm Hello, Need your help, My builder told me that it will to get approval for real balcony through CDC, is that true? Building double storey house @ Macarthur heights Land size 400m^2 Build 25 Square With 12 m Depth 32 Re: CDC Clause question. 4Feb 10, 2021 8:30 pm Nemkul128 Hello, Need your help, My builder told me that it will be harder to get approval for real balcony through CDC, is that true? Building double storey house @ Macarthur heights Land size 400m^2 Build 25 Square With 12 m Depth 32 Re: CDC Clause question. 5Feb 10, 2021 8:51 pm Nemkul128 Hello, Need your help, My builder told me that it will to get approval for rear balcony through CDC, is that true? Building double storey house @ Macarthur heights Land size 400m^2 Build 25 Square With 12 m Depth 32 Unless there is something in special conditions the builder does not have to give you timeline. If your demolition contractor has not removed Asbestos and it was found… 12 28676 Hi All, see above image. The required setback from the rear boundary in my case is 5m, as you can see the shape of the site and location of the boundary is slightly… 0 8301 I want to build a bigger driveway (without a nature strip) than has been approved under my CDC. I’ve also had a DA approved to build a deck. It looks like I can do this… 0 4783 |
