Browse Forums Building Standards; Getting It Right! 1 Jul 05, 2018 9:57 am Hi team, Need some advise on the below - Background - Purchased the property few years back, where the previous owner had converted the garrage to a bedroom. Structure- The bedroom is build on the timber pierece and on a raised floor. The flooring is an carpet floor Issue - I am planning to apply for a BC to get an approval from the council. The issue is with the height of the property as it is 2.36. What is the recommended solution to raise the height in order get an BCA certificate' Regards, Krishna Unless the room is for storage then it's non compliant BCA V2 2019 S3 P3.8 You have 2 options 1. The builder deconstructs the section and rebuilds as per plan /… 7 10657 ok thanks - yes was wondering if that should have been listed as Option Three! 2 7712 I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 9551 |
