Browse Forums Building Standards; Getting It Right! Re: Brick work around windows 11Aug 26, 2018 9:43 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Brick work around windows 12Aug 26, 2018 10:25 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Brick work around windows 15Aug 27, 2018 1:33 am kathysangel PackieBonner We are the same with our house. We have checked our builder's display homes and our is finished very different around the base of the windows where it meets the brick sills. Looks like the bricky came back after finishing the walls and did the sills really quickly and poorly and possibly ran out of bricks and we can see chips, the cavity holes in the bricks and gaps where the bricks don't go under the window frame, which is causing the flap seal to waiver and not work correctly. I'm even unsure where flashing was installed also. DIY, Home Maintenance & Repair could be the footing or being hard up against the other wall with no expansion joint or both. You could try again with brick mesh and use some sticky back foam against the… 1 1101 You’re on the right track, wire brush in a grinder then a zinc rich epoxy primer then a top coat of some sort, like a waterproofing membrane. Raising the concrete would… 1 7034 |
