Browse Forums Building Standards; Getting It Right! Re: Slab, should I be worried? 2Apr 24, 2018 8:28 am Simonsss Thanks for the photos, Yes you should be concerned The Steel frame overhang needs to be properly supported because The frame is more than likely to be load supporting? Please check your Engineering Details hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs i imagine you also have another contract with an architect? and yeah, whatever other's said about special conditions and appendices 16 16000 hey there! π so, itβs kinda common for standard drawer depths to be around 500mm since most cabinets use this size to fit the usual runners… 3 20902 I've decided, after a period of confusion (my building broker told me it's probably not worth it to use a lawyer, but others have said it is a must) that I definitely will… 7 27951 |
