Browse Forums Building Standards; Getting It Right! 1 Oct 15, 2017 11:16 pm Hi all, We are currently building with a volume builder. At every stage we hired a inspector to check the quality and my site supervisor did not fix most of the issues and the pre plaster report says there are so many doesn't meet Australian standards, stuff like telephone and power lines crossing water pipes without conduit. Even after repeated messages and emails they went and fixed plaster board and meanwhile my site supervisor left the company. It's more than 4 weeks since I got any updates about the status. Construction manager was meant to get back to me but not yet. What do you think about the whole situation? Doesn't the builders has to built according to Australian standards? Do you think they can still fix issues with frame work? Thank you very much [/quote] Re: Australian standards.. 2Oct 16, 2017 4:46 am Your builder has to build in accordance with: 1 Implied warranties which include, work to be done in a workmanlike manner with reasonable skill and care. 2 Standard no less than the display home standard 3 Comply with BCA (NCC) 4 Where BCA references AS, comply with those standards 5 In accordance with contracted plans and specifications If your inspector is worth the money then you should be assisted in your dispute with the builder. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Australian standards.. 3Oct 16, 2017 5:52 am Heavyjelly2015 Hi all, We are currently building with a volume builder. At every stage we hired a inspector to check the quality and my site supervisor did not fix most of the issues and the pre plaster report says there are so many doesn't meet Australian standards, stuff like telephone and power lines crossing water pipes without conduit. Even after repeated messages and emails they went and fixed plaster board and meanwhile my site supervisor left the company. It's more than 4 weeks since I got any updates about the status. Construction manager was meant to get back to me but not yet. What do you think about the whole situation? Doesn't the builders has to built according to Australian standards? Do you think they can still fix issues with frame work? Thank you very much [/quote] We have also hired an independent inspector and found at each stage lots of things have not been built to Australian Standards. Most of these things they have rectified but sometimes the build proceeds and things get covered up making it impossible to check. If I were you I would try to get in touch with someone from higher management. - View my blog at www.waldorfgrangebuild.wordpress.com Re: Australian standards.. 4Oct 16, 2017 8:26 am Heavyjelly2015 Doesn't the builders has to built according to Australian standards? Do you think they can still fix issues with frame work? There's a hierarchy of standards and he's probably picked on one of the less important ones & what you will find is that the builders and Subcontractors don't even have copies of the relevant standards.They are also well informed by their association groups that building inspectors are perceived more of a nuisance factor meanwhile you are spending a bomb on reports... out of your pocket.Structural Non-compliance issues are a ticking timebomb and should be fixed immediately. ..I agree with once covered often forgotten and ignored, have it properly accessed and fixed ASAP. 3 options are 1. Lodge a complaint with management and the building commission 2.Have it fixed and certified independently 3.If Possible fix it yourself my2c Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 7003 I believe this is correct. From the picture you can see the power was put in last so the electrician knew where the water was. Really it's a common sense issue more… 4 5152 2 8643 |
