Browse Forums Building Standards; Getting It Right! 1 Sep 19, 2017 10:38 am Hi Guys, We have just been charged by our builder to have 3 x bollards installed as part of the build. They are approximately $600 for each gas meter. Do these bollards need to meet certain requirements? They just look like hollow metal square poles in a U shape that is concreted to the front of the gas meter. I did do some googling and it mentions that they need to be boxed up in the foundation. Is there a way that I can check after the installation? Cheers 4 10821 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20226 you need a fridgie to answer but I would think you vac the whole system then add gas if you have a leak, unless it is new install with the gas already loaded, in that case… 1 3657 |
