Browse Forums Building Standards; Getting It Right! 1 Aug 25, 2017 4:02 am New build I was out there today and there is about 50mm gap that runs down the hallway wall that backs on to the side of my garage wall about 6meters long how will this gap be filled in the hall way side and will this promote movement and cracks down the track Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Gap from slab to internal hallway wall 2Sep 11, 2017 8:59 pm Hi erecttvantennas, I assume the following: the slab belongs to the garage and was poured after the house walls were in... and that the house has a timber floor (on the right in photo 1). IF so, then I would be very worried about a complete lack of ventilation to the sub-floor along this abutment AND risk of termite attack. I assume that the wall was there before the garage slab... and it seems that the wall has problems at the bottom course and may be curved. There is a requirement that a slab poured against an existing brick wall needs to be separated by a control joint. If the house is a concrete slab that was poured first and the garage slab was built later (seems unusual to have what appears to be particleboard atop the house slab. Give us a shot from the hall side and elevation of the bottom joint of the brick wall if you would. Re: Gap from slab to internal hallway wall 3Sep 12, 2017 9:08 am @erecttvantennas you need to provide more information like, where you are located , soil type, wall construction etc The quality of the answers depends on the information provided by you! Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs 2 7482 Might cheaper to changer your idea of what makes a home, have you considered building a porch? 2 51774 at most it will have a short lintel which could be moved up just below the ceiling or even above. Above means you need to patch the cornice and might need to deal with… 2 61346 |
