Browse Forums Building Standards; Getting It Right! 1 Apr 10, 2017 3:48 pm Hi everybody. I have a query I'm hoping someone can help me with in relation to the NCC. I have a scenario where water leaks through the back door of my garage each time it rains. Right now damage is minimal but likely to get worse over time. Ive raised it with the builder who've fobbed me off, giving me the "not required for class 10 buildings" excuse. I've checked the NCC and the below is the relevant excerpt: P2.2.2 Weatherproofing A roof and external wall (including openings around windows and doors) must prevent the penetration of water that could cause— (a) unhealthy or dangerous conditions, or loss of amenity for occupants; and (b) undue dampness or deterioration of building elements. Limitation: P2.2.2(a) does not apply to a Class 10 building except where its construction contributes to the weatherproofing of the Class 1 building. Does this mean that i can argue that (b) is still relevant? effectively the water ingress can cause deterioration to building elements? I can imagine the builder response will refer to the limitation set out in P2.2.3: P2.2.3 Dampness Moisture from the ground must be prevented from causing— (a) unhealthy or dangerous conditions, or loss of amenity for occupants; and (b) undue dampness or deterioration of building elements. Limitation: P2.2.3 does not apply to a Class 10 building where in the particular case there is no necessity for compliance. However when I read 2.2.3, it reads as if the dampness being reffered to is only dampness from the ground, not dampness from water ingress. Look forward to some educated responses! Many thanks in advance Re: Weatherproofing to class 10 buildings (NCC P2.2.2) 2Apr 10, 2017 5:34 pm You are right P2.2.2 applies Have you checked display home and Your drawings and specification. Slab should either be set down or be sloping toward outside to prevent water coming into the garage. Maybe a weather seal will work. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Weatherproofing to class 10 buildings (NCC P2.2.2) 3Apr 10, 2017 8:14 pm Nothing to do with the slab. The water is entering through the back swing door that is not weatherproof. Re: Weatherproofing to class 10 buildings (NCC P2.2.2) 4Apr 13, 2017 10:33 am weather seal on the frame then Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Weatherproofing to class 10 buildings (NCC P2.2.2) 5Apr 13, 2017 11:25 am none of these actually ansered the question. I have since gotten a response from the VBA. 2.2.2b is still relevant for class 10 buildings, they are not exempt as the builder would have tried to have me belive. yes a weather seal is a potential solution. The issue was the builder claiming the garage door was exempt from being weatherproof...because while they might be able to nail two boards together (maybe) they certainly have trouble with comprehension thanks guys! yes this is how I've exactly raised it with the builder. still awaiting response. 12 6064 Whats in the gap between the fence and the concrete? I assume dirt/plants etc, right? like youve shown in other parts of the pics. Im not sure how familiar you are with… 8 6062 10 years ago was a different software than we use now. it has had a lot of changes over the past years. Improvments to the software and changes to how Nathers models need… 8 1512 |
