Browse Forums Building Standards; Getting It Right! 1 Aug 17, 2016 1:05 am Hi all... Heres my house... Matrix cladding was completed on top of the garage but something looked off on the edge of the wall where it meets the render. Builder has advised it still needs to be sealed off with sealant and timber. Ive never seen timber on top of the matrix cladding... Its usually very clean straight edges Have they done something wrong during the install? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Heres a closer look.. Any help appreciated please, so I can tell them to fix it now. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: MATRIX Cladding wall edge 3Aug 17, 2016 6:59 pm Yes that is one way that the matrix can be finished off as it becomes an explanation joint between the masonry and the cladding and as long as the flashings are done correctly from the top down it should be okay the other way would be to butt the matrix up to a length of moulding that is against the brick Re: MATRIX Cladding wall edge 4Aug 17, 2016 9:12 pm jsm009 Yes that is one way that the matrix can be finished off as it becomes an explanation joint between the masonry and the cladding and as long as the flashings are done correctly from the top down it should be okay the other way would be to butt the matrix up to a length of moulding that is against the brick Thanks JSM....sets my mind at ease Hi, Currently building, we are on a sloping block so we have from floor level to the roof in axon cladding. Below floor level to the ground I want to put brick facings /… 0 4497 Hello everyone, After some suggestions and ideas about how to put a concrete path around the drop edge beam area on our new build. We are required to have a concrete path… 0 12878 |
