Browse Forums Building Standards; Getting It Right! 1 Jul 25, 2016 9:28 pm Hi We are building our dream home that is quickly turning sour! We have had nothing but problems with the build and the latest is the bricks. Now I'm not a brickie but to me these look like big problems. Any feedback and advice welcome!! The alfresco pillar Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The kitchen window The lintel is sagging and bricks "swelling" Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The joint cracking 7 courses up Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The colour difference in bricks Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The difference in Mortar colour Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The gap above the window Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The difference in joint depths Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Sorry for the pic overload but we are worried and our concerns aren't being listened too. Thanks Re: ** job on bricks 3Jul 26, 2016 3:22 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using siphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost, siphonic, eaves gutter overflow solution. Re: ** job on bricks 4Jul 26, 2016 4:33 pm very poor standard of bricklaying,even proper cleaning is not going to help that much. I would be speaking with the SS to start with and if you get no joy from him get a independant report. where abouts are you building ? Re: ** job on bricks 6Jul 27, 2016 12:48 am Tim65 very poor standard of bricklaying,even proper cleaning is not going to help that much. I would be speaking with the SS to start with and if you get no joy from him get a independant report. where abouts are you building ? Hi We have an inspector...... I'm actually scared to let him see it! He wasn't too happy with the last inspect with the slab and they are yet to fix those issues. how much influence does the inspection report actually put onto the builder? What is the best way to use it to our advantage other than to just highlight the issues? Re: ** job on bricks 7Jul 27, 2016 12:49 am everafter140 Tim65 very poor standard of bricklaying,even proper cleaning is not going to help that much. I would be speaking with the SS to start with and if you get no joy from him get a independant report. where abouts are you building ? Hi We have an inspector...... I'm actually scared to let him see it! He wasn't too happy with the last inspect with the slab and they are yet to fix those issues. how much influence does the inspection report actually put onto the builder? What is the best way to use it to our advantage other than to just highlight the issues? We are building in Sydney Re: ** job on bricks 8Jul 27, 2016 8:22 am Influence is relative. If you've got a stubborn ss or builder it won't influence at all. That bit is up to you. The report arms you with facts and references to the code that have not been met. It's up to you to push the buttons unless it's specified that the inspector will act for you to resolve the issues to conclusion Creator of superduperonium, expert at expert things, nobel laureate, can hold my breath for 10 minutes. Re: ** job on bricks 9Jul 27, 2016 2:16 pm Agree with what Ponzu has said , I would tell the builder straight if its not sorted you will take it further, dont be put off by the builder, keep records of all correspondence and tell the build you require in wrighting his proposals how he is going to fix it and a realistic time scale. He might try to give you BS but stay strong .If no joy get in contact with fair trades NSW they may have a case load against him already.Is he a member of the MBA if so get a complaint in with these as well if he wont fix the problems. Good luck Regardless of wall hung toilet or floor pan toilet your feet will be right on drain, seems to me the waste should not be in that location given the design. Also are you… 6 16500 Last year I had a gas leak at my house. 3 days later, I have about 1 sqm of my exposed aggregate paving broken up. I am not sure how to go about getting it repaired… 0 19842 Thanks for much mate. I see that you do cabinets before flooring. For timber flooring, for most parts it's fine because it's got base plates, and for door jabs you can… 7 23776 |
