Browse Forums Building Standards; Getting It Right! 1 Jul 03, 2016 8:38 pm Hi all, I would appreciate technical details on options in regards to the following. 1. James Hardie Axon to brick subfloor junction. 2. Colorbond corrugated sheet cladding (horizontal) to brick subfloor junction. 3. James Hardie Axon to Colorbond corrugated sheet cladding (horizontal) junction. The house will be built using timber stud frame, timber floor, with brick subfloor. My drafty has mentioned a couple of times in our meetings to use flashing to go over the brick but the installation documentation for the Axon and other similar cladding systems i.e shadowclad shows no such option, instead they all show a flush option? Thanks Tony Jimbo73 I would use heaps of adhesive on each sheet and screw rather than nail. use as many as you like cheers Simeon 1 4064 XCEM Alpha flooring seems to relatively new and I could not found any reviews. Have you or someone you know have used it and would recommend over other subfloor options?… 2 7590 Would also like an opinion from anyone that has used xcem over hebel for floors. Thanks 1 14230 |
