Browse Forums Building Standards; Getting It Right! 1 Jun 24, 2016 12:03 am Hi Guys, First post here however have been reading on this forum for sometime. We have been extending our home and have now just finished laying the bricks for the garage. Today i noticed the bricks on top of where the garage door is going seems to be leaning outwards on the first two rolls. I know i will be rendering the walls but it seems odd that the bricks are leaning out wards. Should i be worried? or am I just thinking too much. Cheers Frank Below are some images http://s1146.photobucket.com/user/franksun871/media/IMG_20160622_211044704_zpsz5tpdmw0.png.html?sort=3&o=3 http://s1146.photobucket.com/user/franksun871/media/IMG_20160622_211004888_zpszk3oyvcr.png.html?sort=3&o=2 http://s1146.photobucket.com/user/franksun871/media/IMG_20160622_211012507_zpsoo1lkyyr.png.html?sort=3&o=1 http://s1146.photobucket.com/user/franksun871/media/IMG_20160622_211044704_zpsbcgdhuwi.png.html?sort=3&o=0 Re: Brick work should i be worried?? 2Jun 30, 2016 6:19 pm IMO it looks like the lintel isn't quite deep enough to take the brickwork and the back of the bricks are sitting on the welded seam Being a builder is more than just having once held a hammer. It's about the trades you hire and ensuring that they give a result that meets the industry standard and the home owners expectations. Re: Brick work should i be worried?? 3Jul 01, 2016 10:41 am Who supplied the steel lintel ? It should have been a 150 x 100mm gal angle or at least 100 x 100mm depending on the span and load above. As per abs above, the weld or roundness at the back of the lintel you show is pushing the brick further to the front. Using a wider lintel also stops you seeing those brick holes from below. Stewie DIY, Home Maintenance & Repair could be the footing or being hard up against the other wall with no expansion joint or both. You could try again with brick mesh and use some sticky back foam against the… 1 1109 I posted the floorplan on Houzz.com forum and got some really good ideas and advice from people there. Then we reached out to a couple of renovation companies and one… 5 10227 1) I had requested R6 ceiling insualtion batts, however I noticed that on some areas there are huge gaps which will allow hot air to sweep in, and also noticed black/grey… 0 4305 |
