Browse Forums Building Standards; Getting It Right! 1 Jun 20, 2016 11:21 am Hi I'm building my first home and week out from handover we have noticed some poor brick work. Is it worth getting the builder to re lay the bricks or be compensated? How much should we ask for? IMG_5117.JPG IMG_5165.JPG IMG_5163.JPG IMG_5170.PNG- the step is dead straight we put a level on it but the wall is not as you can tell by the bricks along the step Re: Unacceptable brick work 2Jun 20, 2016 11:27 am Sorry, can not see the photos. ~Shellby~ GJ Bridgewater 203 11/3/2016 - Site Work Started 29/9/2016 - Handover 142 Work Days 6 Work Days Over https://forum.homeone.com.au/viewtopic.php?f=31&t=80174 DIY, Home Maintenance & Repair could be the footing or being hard up against the other wall with no expansion joint or both. You could try again with brick mesh and use some sticky back foam against the… 1 1109 I posted the floorplan on Houzz.com forum and got some really good ideas and advice from people there. Then we reached out to a couple of renovation companies and one… 5 10225 1) I had requested R6 ceiling insualtion batts, however I noticed that on some areas there are huge gaps which will allow hot air to sweep in, and also noticed black/grey… 0 4274 |
