Browse Forums Building Standards; Getting It Right! Re: How does our builder fix this issue? 21Jun 27, 2016 8:17 pm The Engineer sent an email to the builder stating in his opinion the beam is both external and internal. He recommended that the beam be replaced but then his next in command said it could be treated. So today they got a steel fabricator out and he is now going to sand blast the beam and coat it. I rang our engineer back up and asked what happens to the gal angle that has been wielded to the beam. Will that now be taken off as to treat the entire beam. He said no they will now completely wield the gal leaving no gaps around the edge. Meaning in his opinion if oxygen and moisture can't penetrate behind the gal angle it should all be fine. I have to say we are far from impressed with what is happening at the moment. But that said we have to move forward and fight battles we know we can win and not hold the build up. Re: How does our builder fix this issue? 22Jun 29, 2016 10:45 am By the sounds of it that beam needs to go. Looking at your pictures I can see there is rust and given your location the right thing to do is either send it off to be hot dipped or a new hot dipped beam. If they are telling you it needs to be sandblasted, that alone sends red flags up. What on earth are they playing at. Re: How does our builder fix this issue? 23Jun 29, 2016 7:29 pm The links below should be of some interest. http://www.vba.vic.gov.au/__data/assets ... tation.pdf http://www.abcb.gov.au/Resources/Public ... th-the-NCC 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: How does our builder fix this issue? 25Jul 12, 2016 11:38 pm gcambo Well the beam was taken down and has been sent off to be sandblasted and hot dipped Gal. So after weeks of nothing happening we are two steps forward one step back. Great outcome for you and it is as it should be. I come from a background of doing government contracts with architects in charge. If we made a mistake we got a defect notice to pull it up and do it again. there was no argument and nowhere to go but to do it. Domestic builders try and do get away with a blue murder because there is insufficient vigilance in compliance. Instead of wasting everyone's time your builder should have done what he is doing now weeks ago. Cheers for you. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog the conduit would need to be undamaged regardless of what network is in play. The conduit needs to be able to have fibre run through it. NBN and Opticomm are just… 4 2881 Hey guys, what’s everyone opinion on James Hardie linea direct fix to frame? Would this be the most common method and anybody ever had any problems down the track? 0 5142 DIY, Home Maintenance & Repair If the railhead is so poorly fixed it is also likely that the railhead is also non compliant, what about overflows and sealing railhead to the gutters?. 3 5967 |
