Browse Forums Building Standards; Getting It Right! 1 Jun 10, 2016 8:13 pm This post is a two-parter. My house is currently under construction under Newcastle City Council. My builder didn't put any retaining walls on my DA plans but I clearly need them. In my estate it is a requirement to have lapped and capped timber fencing so the common thing is to do the normal fence with pine sleepers underneath it. 1) My neighbour on one side is a builder and his brother is a fencer. He cut his block 800mm to get his driveway lower whereas my block was a 400mm cut and fill back to front. He has already done the fence and hit me up for half which I wasn't too pleased about since he had a massive cut but according to the Dividing Fences Act sleepers under a fence aren't technically a retaining wall and are considered to be support for the fence (http://www.austlii.edu.au/au/legis/nsw/ ... 37/s3.html). This means I needed to pay 50% of the total. Is that true? I paid it because I didn't want the confrontation and he seemed to know what he was talking about. I've also just now looked at the NSW SEPP and under Section 29 (5) (http://www.legislation.nsw.gov.au/#/vie ... /572/whole#%2Fpart3%2Fdiv2%2Fsubdiv6%2Fcl3.29) it states any wall over 600mm located on the boundary needs to be designed by an engineer. I'm almost certain this wasn't done. The fence in question. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 2) With that in mind, am I required to apply for a DA modification for my other "retaining walls" (pine sleepers)? The other ones I need are all under 400mm. Re: Retaining wall - DA required for pine sleepers? 2Jun 24, 2016 8:21 am Suggest you try this website to check the planning rules that actually apply to your house. It's easier than trying to interpret the full DA regulations. You plug in your address and it will tell you which rules apply including decking, pergolas, carports, and retaining walls. http://interactivebuildings.planning.nsw.gov.au/ Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5197 DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 6592 Iām just in the process of replacing 2 stud walls that have been severely damaged by termites and am planning to use h2 blue pine. I just wanted to if anyone can advise… 0 52859 |
