Browse Forums Building Standards; Getting It Right! 1 Jun 08, 2016 7:15 pm Our DA states: Due to the position of the site, all external structural steel is to be hot dipped galvanized & the brick ties are to be stainless steel as required under the BCA. We have noticed that the nails used in the frames are Bright steel D head nails. Should they have used hot dipped gal nails? Re: We have noticed that the nails used in the frames are Br 2Jun 09, 2016 1:26 pm if they are using treated timber they should be using galv nails, its quite a common thing i have come across with a lot of builders i have sub contracted to, all down to the cost of box of nails ,also if its 90 x 45 timber they should be min 82 long not the common 75 again its down to cost. Re: We have noticed that the nails used in the frames are Br 3Jun 09, 2016 7:45 pm The nails used on brackets to connect the roof truss to the top of the frames. As it turns out all the frames were supposed to be nailed with gal nails as well. Then as of today just found out the big metal girder used across the front of the first floor connecting the main balcony was suppose to be hot dip Gal but apparently it's not! That sucks! Hope it all works out. Good to move away from steel anyway for all your reasons, but it's also thermally poor. 16 17875 If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8306 |
