Browse Forums Building Standards; Getting It Right! 1 Jun 02, 2016 5:46 pm Lots of builders are using pressure seal, they will always fail in a couple of years. Inspired a new house today and flashing is already coming apart. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ And here is another photo of why commercial window will always be better than residential grade Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I know this post is from a while ago, but the VBA has some good guidance on this. https://www.vba.vic.gov.au/__data/asset ... 5-Roof.pdf 2 10758 AFAIK, flashing is a minimum standard. Out of curiosity is your window glass stamped with AS requirements in any of the corners of each pane? Im almost certan if theyre… 2 6305 Building Standards; Getting It Right! There doesn't look to be any rebate in the slab to prevent water from scooting under the window. AS4654 is the Australian standard to look at/refer to. They have… 1 10188 |
