Browse Forums Building Standards; Getting It Right! 1 Apr 10, 2016 8:53 pm Hi everyone, I'm stuck in a limbo with 2 questions here. What notice needs to be provided in or near the meter box on the completed dwelling? To comply with NCC deemed to comply provisions, when termite inspections are required, what is the minimum required distance between ground level and the underside of bearers at a distance of 2.5m from the inside face of external walls? I think its 400mm, but i'm not too sure! just want to confirm. Thanks! Re: Confirming some Standards 2Apr 12, 2016 12:37 pm minimum 150 at wall. 400 at 2000 Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 7014 I believe this is correct. From the picture you can see the power was put in last so the electrician knew where the water was. Really it's a common sense issue more… 4 5161 2 8648 |
