Browse Forums Building Standards; Getting It Right! Re: House built 30cm to the right 41Apr 06, 2016 10:58 pm The council have said that the house requires some modification and the neighbours need to agree. The builder will be meeting with the neighbours in a few days. Obviously if the neighbours don't agree the house will be rebuilt. Re: House built 30cm to the right 42Apr 07, 2016 9:56 am At the end of the day what you now have is not what you wanted regardless of any compensation. I would explore again the option of builder buying you out. I have been successful in getting one of my clients bought out of a problem home in QLD. I am an advocate of changes to consumer protection so that any new dwelling with serious problems that cannot be fixed is declared insurance write off and owners bought out at market value. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: House built 30cm to the right 43Apr 07, 2016 7:44 pm What about the tiny back yard that has resulted from the error, the decrease in value and need for privacy screening that was a source of concern to you? Is a few windows really enough compensation? Re: House built 30cm to the right 44Apr 08, 2016 1:26 pm People here are warning you not to compromise needlessly. I agree. You hold all the cards - the builder did not meet the spec, so its 100% his responsibility. At worst he has to totally rebuild, least worst he could buy the block from you. The latter option would be far more preferable to the builder than the former option. Dont allow yourself to be sold short on this. The builder stuffed up even though his licensing ostensibly declares that it should not happen. It is fair that the builder pays a substantial penalty whatever the outcome, since this is a very stupid mistake on its part. Re: House built 30cm to the right 45Apr 08, 2016 3:13 pm Kei We only had an independent inspector at lock up. We had also paid for a survey that the builder has now informed us did not occur. Obviously we'll be asking for a refund on that! Have you had discussions with the builder and asked how this happened? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: House built 30cm to the right 46Apr 08, 2016 9:11 pm Agree with qubtel. Be really careful to agree just because they are being nice. Of course they are playing nice, they don't want you to force a rebuild. Also, why are you even discussing a reduction in final payment? Surely that is only 10% of the total build cost. I don't know the cost of your build or the total value of your finished product but 10% off seems like the absolute least they should be offering.... Plus the other stuff you have mentioned. I, personally, don't think you should be spending one more cent. Re: House built 30cm to the right 47Apr 11, 2016 12:24 pm Kei They were supposed to get another certified survey done after the footings were poured as the size of the blocks in my area (inner-city) are small, so it's important that they are correct! This survey was never booked or conducted, however we were charged for it. Definitely a contributing factor, no way a surveyor would have missed this error. rocketship Also, why are you even discussing a reduction in final payment? Surely that is only 10% of the total build cost. I don't know the cost of your build or the total value of your finished product but 10% off seems like the absolute least they should be offering.... Wear those "big pants" well and authoritatively.. Re: House built 30cm to the right 51May 03, 2016 11:29 pm Hi, I have the same issue the builder has built the house 30cm to right of the set back. Could you share what was the outcome of the builder's meeting with the neighbours? Were you allowed also to attend? Also, is there a standard deviation tolerance that the council would allow as a reasonable error? Cheers, Gadi Re: House built 30cm to the right 52May 13, 2016 6:28 pm I wouldn't think 30mm will be an issue if your home is contained within your property Re: House built 30cm to the right 55May 14, 2016 12:47 pm Big stuff up. How they get the first floor wrong?? Ground floor must be out too Re: House built 30cm to the right 56May 14, 2016 12:57 pm There is 1.5m width on the ground floor between our set back and the neighbouring fence, however on the plans the 1st floor set back was supposed to be 1.8m but now it's only 1.5m. Is this within the tolerance deviation level, or will the builder have to demolish and rebuild? Re: House built 30cm to the right 57May 14, 2016 5:34 pm There is no tolerance. House must be built as per the plans unless you approve a variation. So the ground floor and first floor is 1500mm from the boundary in lieu of 1800?? What stage are u up too, was it pegged out wrong and are you happy for it to remain? Re: House built 30cm to the right 58May 14, 2016 6:06 pm Can't edit but was going to say 50mm not 30cm I'm putting a new floor in my kitchen, slate flagging on a standard concrete slab. I have allowed for a bed thickness of up to 20mm to accommodate the different… 0 17536 They using concrete or timber sleepers? Timber or steel uprights? Any drainage behind sleeper? 3 5828 Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 9527 |
