Browse Forums Building Standards; Getting It Right! 1 Mar 20, 2016 4:49 pm Hey guys, As per the screenshot below, the inspection report came back saying the perpends were uniformly larger than the A.S allowance of 10mm. Is this something worth bringing up with the builder? Nothing can really be done about it now as the roof frame is on. Should I just let this one slide? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ My build with FHBD viewtopic.php?f=31&t=78344 Re: Standards for brick perpends - worth taking any action 2Mar 20, 2016 7:47 pm Daz_ Hey guys, As per the screenshot below, the inspection report came back saying the perpends were uniformly larger than the A.S allowance of 10mm. Is this something worth bringing up with the builder? Nothing can really be done about it now as the roof frame is on. Should I just let this one slide? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thank you for this. We have the perpends that range from 10mm up to 22mm and I haven't seen the reference to the standard. Queensland just changed their standards and tolerance guides to be up to 20mm. Sorry I can't help on what they can do. Building a modified Madison 39 with Clarendon Homes in Tennyson homeone link: viewtopic.php?f=31&t=79106 Blog Link: https://minandb.wordpress.com/ Re: Standards for brick perpends - worth taking any action 3Mar 21, 2016 7:15 pm Haha I'm glad I could help If the QLD standard is 20mm then mine been 15mm in some areas surely isn't a huge deal even if it technically doesn't comply to WA standards My build with FHBD viewtopic.php?f=31&t=78344 Re: Standards for brick perpends - worth taking any action 4Jun 30, 2016 6:36 pm What DW specification is the brick you selected? If it's DW1 a perp end dimensional tolerance is 10mm +/- 3mm [ie 7mm-13mm] If they are rated DW0 there is no perp end dimensional tolerance. The pics make me assume the brickwork is a 290mm [Long] x 162mm [High] x 90mm [thick] block. If so it shouldn't be laid on a third bond but instead using a 240mm long block on each course left/right the external corners allowing a transition into a standard half bond for the rest of the wall. Being a builder is more than just having once held a hammer. It's about the trades you hire and ensuring that they give a result that meets the industry standard and the home owners expectations. The fastest thing a builder will do is bank your cheque, those systems work perfectly with lightning speed, everything else is slow burn. Just the way it is. 1 8702 Can someone please offer some advice? Im DESPERATE. Because I'm completely and utterly exhausted. How long are variations taking with other companies at the moment? We… 0 18436 Thanks. I called VBA today and they said it was a Consumer Affairs issue, the old handball. Seems like the government organisations don't want to do their job at the moment. 2 7542 |
