Browse Forums Building Standards; Getting It Right! Re: Standards for brick perpends - worth taking any action 2Mar 20, 2016 8:47 pm Building a modified Madison 39 with Clarendon Homes in Tennyson homeone link: viewtopic.php?f=31&t=79106 Blog Link: https://minandb.wordpress.com/ Re: Standards for brick perpends - worth taking any action 3Mar 21, 2016 8:15 pm My build with FHBD viewtopic.php?f=31&t=78344 Re: Standards for brick perpends - worth taking any action 4Jun 30, 2016 7:36 pm What DW specification is the brick you selected? If it's DW1 a perp end dimensional tolerance is 10mm +/- 3mm [ie 7mm-13mm] If they are rated DW0 there is no perp end dimensional tolerance. The pics make me assume the brickwork is a 290mm [Long] x 162mm [High] x 90mm [thick] block. If so it shouldn't be laid on a third bond but instead using a 240mm long block on each course left/right the external corners allowing a transition into a standard half bond for the rest of the wall. Being a builder is more than just having once held a hammer. It's about the trades you hire and ensuring that they give a result that meets the industry standard and the home owners expectations. The fastest thing a builder will do is bank your cheque, those systems work perfectly with lightning speed, everything else is slow burn. Just the way it is. 1 5613 Can someone please offer some advice? Im DESPERATE. Because I'm completely and utterly exhausted. How long are variations taking with other companies at the moment? We… 0 11943 Thanks. I called VBA today and they said it was a Consumer Affairs issue, the old handball. Seems like the government organisations don't want to do their job at the moment. 2 5706 |
